I checked the stickies but no answer???
First off I check the stickies and I didn't get my answer.......
Everyone that lowers their car pairs their springs up wit adjustable struts.....
Can u just lower the car wit the springs and stock struts or do u have to pair them up wit adjustable struts???
What do u loos if u pair them wit stock struts.....
People say that if you lower it mainly more than 1.5 that you will blow your stock struts. Also, alot of people prefer the adjustable so you can change the settings. I don't plan on doing the adjustable just for the simple fact that my driving habits don't change nor do I drive on many different types of roads. If a road is f****d up, I usually avoid it. I'm not any kind of expert on struts or anything, but I think you will be fine just getting the hp's, paired with the progress, unless you want more of a drop. Then of course you can go with the s-techs, in which they say your stock struts will die pretty soon.
It may not be in the stickys, but it has been covered a THOUSAND times before...
With ANY lowering spring, your spring rate will be too strong for th estock damping to handle and your struts- even if brand new- will blow out. Between the increased load on the damping and the increased chances of the strut bottoming out (travel in excess of design limits), you will inevitably blow your struts very quickly.
Originally Posted by brandnew
What about eibachs will they blow wit them
Originally Posted by phenryiv1
With ANY lowering spring, your spring rate will be too strong for the stock damping to handle and your struts- even if brand new- will blow out. Between the increased load on the damping and the increased chances of the strut bottoming out (travel in excess of design limits), you will inevitably blow your struts very quickly.
Wooooe hold ur horses tonto u must have posted that like 1 second before I hit reply when I typed mine cuz ur reply wasn't there when I sent mine threw....
And yes u were clear thanx for the reply
But no need 4 the attitude
just a suggestion http://forums.maxima.org/showthread.php?t=526594 post #23
no aggression, just a suggestion
from here.And the answer was given: any springs will be bad on your stock struts after a given period of time.
people dont pair them with only adjustable strut/shocks its just they perfer to use them and pretty much you only main option. Because the non-adjustable strut/shocks are mainly just OE replacements. Which means they are just the same as your STOCK stuff maybe 1 step better or worst.
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Keyno McMike
Sep 21, 2015 07:18 AM
pears
Sep 18, 2015 05:25 AM
