Homelink!
Old Oct 19, 2000 | 06:16 PM
BrianV's Avatar
Does the homelink unit on the 97 SE work with Rolling Code Garage Door Openers? I lost my car's manual and don't have the instructions, so I took my father's instructions, 2001 Acura 3.2CL and his work for resetting it but not for programming. However, we have a Rolling Code Garage Door Opener and the Acura handbook says something like, "Homelink also includes support for new anti-theft rolling code systems"
I'm thinking in 97 it wasn't programmed to support that yet?
If someone could read me the instructions on how to program a button and if they've been able to program with Rolling Codes? Genie calls their system, "Intellicode"
Old Oct 19, 2000 | 06:39 PM
MaximaZero's Avatar
Needs non-Maxima Friends
our 97 i30t's homelink system works with our rolling code garage door openers. i dont see why the maxmima's shouldnt.
Old Oct 19, 2000 | 08:23 PM
BrianV's Avatar
Can you type the instructions on programming it. I know how to reset the system, but someone please just tell me how to program it.
Thanks for the reply, I have hope now!
Old Oct 20, 2000 | 06:06 AM
jmottle
Brian,
I just happen to have my manual with me this morning. I've scanned the pages you'll need. Hope that's what your after.
Jeff
Old Oct 20, 2000 | 01:17 PM
BrianV's Avatar
Ok thanks, but I still need the info on how to originally program it.
Old Oct 20, 2000 | 01:40 PM
La Jolla Max's Avatar
Well, on my 99SE w/homelink, you hold the garage door transmitter up to the homelink cluster, and press garage transmitter button and homelink button you want to use at the same time, and hold them for 30-40secs. what'll happen is the LED on the Homelink transmitter will stay on for around 30 seconds, and once its been programmed it'll start blinking repeatedly until you release the button.
Hope this helps. Course I have no idea if the 97 and 99's have different homelink systems
Old Oct 20, 2000 | 03:30 PM
BrianV's Avatar
Well mine blinks slowly when I hold it down, and according to my dad's acura's instructions it should start blinking rapidly when programmed, but I've held mine up there for a while and it hasn't received it. Maybe I just didn't do it long enough.
Old Oct 20, 2000 | 04:58 PM
max1ma97se's Avatar
hold button
hold the button on the homelink tht controls far right 1 and push the portable garage control tht came with your garge opener and it should work
Old Oct 21, 2000 | 01:06 AM
BrianV's Avatar
I held the garage receiver down then I held the third button down. After about 60 seconds the homelink stopped blinking and it doesn't appear to be charged?
Old Oct 21, 2000 | 06:23 AM
nortynorty's Avatar
Here's a link to the Homelink page which might help. I think on a rolling code GDO you need to go to the main unit to do the programming and not use the hand held transmitter.
http://www.homelink.com/gettingstarted/garage.html
Old Oct 21, 2000 | 12:53 PM
BrianV's Avatar
Yeah apparently the Maxima's Homelink just doesn't work with my Genie Intellicode system. It just won't accept receivers information. However, my dad's 2001 Acura does =(
Old Oct 21, 2000 | 02:47 PM
tony
Is there a part number?
Howdy all:
Is there a part number for the visor with the homelink that would fit in a 96 with a tan interior?? I would love to put one in my 96. Would I have to run power to it??
I would appreciate any help.
Best regards,
tony
Old Oct 21, 2000 | 08:36 PM
nismomaxse97's Avatar
My 97 will not work with rolling code
I called Homelink personally to find this out.
I thought i was doing it wrong my self.
Old Oct 21, 2000 | 10:39 PM
BrianV's Avatar
Ok at least I know not to waste anymore time trying.
Old Oct 26, 2000 | 05:40 PM
BEJAY1's Avatar
Conecarver
GE Intellicode solution
BrianV - I had the same dilema with the GE and the '97 homelink. Lots of people on the NissanUSA board where asking too (don't ask why I bothered reading there)
Nissan customer service sent me an adapter called "Lift Master Security Plus". Plugs into an AC outlet and your GDO main unit. That made my homelink talk to the GE.
Don't know if they'll still send these free but it's worth a try.
Had homelink and REALLY didn't want the GDO on my visor.
Old Oct 26, 2000 | 11:41 PM
BrianV's Avatar
I'll give it a try.
Huttig2009
Sep 25, 2015 03:31 PM
Gildarts
Aug 31, 2015 07:10 AM
Nick97SE
Jun 4, 2003 04:45 PM
Myrv
Oct 14, 2002 09:31 AM
bluemodena
Jun 10, 2002 02:38 AM
