Clutch
Old Jul 24, 2001 | 07:32 AM
  #41
Curt Deiner's Avatar
Re: Re: Re: 5-speed PNP switch
Originally posted by Daniel B. Martin
1) Rev limiter.
The ECM prevents engine operation above a preset rpm threshold. This is to protect the engine. It has nothing to do with gearshift position.
[/B]
So my '97 SE 5spd has this? I could stand on the throttle and it would bounce off, what? 6700 rpm? btw I wouldn't do this, but was wondering if the engine was protected if I wasn't looking at the tach like in an on ramp situation.
Old Jul 24, 2001 | 07:50 AM
  #42
Daniel B. Martin's Avatar
Re: Second Opinion
Originally posted by QikEnuf
... My other question is do the bearings in the transmission move while in neutral ...
Yes, they do.
Old Jul 24, 2001 | 07:55 AM
  #43
QikEnuf's Avatar
Re: Re: Second Opinion
Would they follow engine RPM?
Yes, they do.
Old Jul 24, 2001 | 07:58 AM
  #44
MaxedOut97SE
Yes, they do.
When mine were bad you could only hear them when the car was in first, never in neutral- that's how I came to the realization that something was wrong with my tranny. What do they do different in neutral?
Old Jul 24, 2001 | 08:03 AM
  #45
QikEnuf's Avatar
Re: Re: Re: Second Opinion
Mine can be heard in neutral and in first and follows engine rpm but goes away when the clutch is depressed
Old Jul 24, 2001 | 08:20 AM
  #46
Re: Re: Re: Re: Second Opinion
When the clutch is disengaged the rotating parts in the transmission slow down and then stop. A noisy bearing would become silent.
Old Jul 24, 2001 | 08:41 AM
  #47
There are several bearings inside your Transaxle. The sounds and symptoms will vary somewhat, depending on which bearings are damaged.
Go to http://www.motorvate.ca/ and click on the 5-Speed Rebuild. There are some good pictures of failed bearings. Click on the thumbnails for an enlarged image.
Old Jul 24, 2001 | 09:18 AM
  #48
MaxSE98's Avatar
Re: RE: Clutch
i did the clutch on mine at 66k, i got a jim wolf stage two and i love it ,ive got more than 1000 on it now and it makes the wheels hop like crazy into second and i can chirp third occasionally which i love even fourth makes yer body fly , i highly recomend it
maxse98
Old Jul 24, 2001 | 10:41 AM
  #49
QikEnuf's Avatar
Re: Re: Re: Re: Re: Second Opinion
Then from what your saying here it sounds like Tranny bearings may be an inaccurate diagnosis from the Dealer because the noise is still heard when the clutch is disengaged....hmm interesting
Old Jul 24, 2001 | 12:06 PM
  #50
QikEnuf's Avatar
Second Opinion
Just got word from the tranny shop and they don't believe that the bearings in the tranny are bad, they think it's more of the throw out bearing. So we shall see..hopefully I don't have to pull it apart again
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
