Tokico Suspension Replacement
Old Jun 26, 2007 | 09:33 PM
MaximA VlaD's Avatar
I bought my 97 SE with tokico struts and red H&R springs (I think). they guys who installed them did a crappy job - no boots, no bump stops, missing strut housing bolts... 1/2-a$$ed job basically. So the suspension went bad.
I hear rattling, squeaking, knocking coming from it when going over ... speed bumps. horrible. I want to replace it. what do you think would be a good comfortable ride, with the same drop - about 1.5 inches, that will last me and the car some trips and won't bottom out like these did on every pothole.
thanks,
Old Jun 27, 2007 | 05:19 AM
phenryiv1's Avatar
Mod her. Ate her.
Tein H-Tech springs, Tokico Illumina struts. OEM strut bearings, KYB dustboots with integrated bump stops.
Old Jun 27, 2007 | 08:01 AM
d00df00d's Avatar
Old enuf to pick his own gears
thanks,
Wow. That is one hell of an incompetently done suspension job.
I second phenryiv1's suggestion, with the possible amendment that you could keep your H&R springs if you want. They might be a little lower and a little firmer than the H-Techs, but not much.
Old Jun 27, 2007 | 09:36 AM
phenryiv1's Avatar
Mod her. Ate her.
I thought that H&Rs were black.
Old Jun 27, 2007 | 10:41 AM
d00df00d's Avatar
You could be right.
Maybe they're Vogtland springs?
Old Jun 27, 2007 | 10:43 AM
AllMaxxedOut's Avatar
Same here last time I checked.
And you can do the install yourself and save your money. Takes about a hour (if that).
Old Jun 27, 2007 | 01:27 PM
MorpheusZero's Avatar
One hour to change out all the springs and struts? Maybe if you have them pre-assembled...
Old Jun 27, 2007 | 10:13 PM
i have to do my axle anyway, so when my new raxle comes, i will do the susp. as well. Just doing research.
I though these red springs were H&Rs, but i guess i was wrong. I would keep them, but the paint is chipping off, so it might be time for them to go before they cause trouble.
I am looking for a bit softer ride - more comfortable. Sounds like H-Techs will be smoother than whatever i have. If the drop is almost the same, thats fine. I just didn't want to go back to stock unless I absolutely had to. Besides, stock is expensive new.
thanks!
Old Jun 28, 2007 | 02:48 PM
max95q's Avatar
Just to give you an idea it took me 4 1/2 to 5 hours to do my suspension swap. Thats with crappy air tools, I mean crappy too. I think is what you have are the Tokico springs.They come mostly with the Tokico Illumina kit. Which is what I have. I like the drop and performance its great. Most people on here dont have them, there are a select few including me. I like the ride. H-techs would be a better bet for you since you are wanting a softer ride. Here is a pic of the Tokico springs with the illuminas on my car after I installed them. So with air tools it will make the job tons easier and faster. I was blessed to even have what I had borrowed from my neighbor.
Here is the pic peeking through my rim.
Old Jun 28, 2007 | 03:14 PM
It took me 2.5 hours with a buddy my first suspension swap. We had crappy air tools and he had done it on his 4th gen before.
Old Jun 28, 2007 | 08:22 PM
just out of curiosity - if h-techs are softer, would that necessarily mean that there will be more "bounce" to the car? technically if the struts are good there should be no bounce, right?
as far as struts, on mine it says Tokico Gas Shocks. I don't have experience with them and don't know if these are illuminas. what's the avg. life expectancy for these? i live in New England with snow and rain and salt and mud on the roads - not favorable conditions for a sport suspension... I just don't want to wind up in the same boat i am in 2 years later.
Old Jun 28, 2007 | 08:55 PM
max95q's Avatar
Bad struts are what make the car bounce because you feel more of the spring action in the spring itself.Good struts will absorb and help control that action . The stiffness of the H-Tech spring will give you a softer ride than the Tokico springs. Plus Tokico gas struts are an upgrade from stock struts but still give you a nice OEM like feel. Tokico Illuminas are adjustable. Soft or stiff ride it will still absorb the bumps and what not from the road to give a good ride.
Old Jun 29, 2007 | 05:31 AM
phenryiv1's Avatar
Mod her. Ate her.
What color are the struts? Tokico HPs are blue and tokico illuminas are white. With the drop of the Tokico springs (which might be what you have) either type of tokico struts should be warrantied, but before you make a warranty claim and say that they are blown, I would disassemble the setup and add in all of the missing parts. The suspension can only do its job when properly bolted to the car.
Old Jun 29, 2007 | 09:40 AM
these are blue - HPs. previous owner put the susp. on - i don't think i can make a warranty claim, i dont have all the info.
Old Jun 29, 2007 | 12:48 PM
phenryiv1's Avatar
Mod her. Ate her.
You can always contact Tokico and ask...
Again, i woudl not be convinced that anything is blown until you get all of the parts off and actually install them correctly.
Old Jun 29, 2007 | 03:30 PM
max95q's Avatar
Yeah, my pic has the white illuminas with the red tokico springs.
Old Jun 29, 2007 | 04:23 PM
Liso's Avatar
I don't mean to hijack the thread, but where can I purchase these?
Thanks,
Danny
Matt93SE
May 24, 2019 02:58 PM
Chef N
Sep 22, 2015 11:20 PM
95Maxi
35
Sep 2, 2015 10:37 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
