help got the C.E.L after putting in a cone filter
i read a post about the cone filters so i went to canadian tire and picked up a cone filter for $25.99. came home and put it on and as soon as i turned car on my check engine light came on. do i have to go back to my ugly stock air box, or is there a solution for this problem?
did you make sure to plug your maf back in that triggers the check engine light also where did you put the sensor from the air box because in 95 the sensor is on the top of the airbox if u cut it theres your problem right there. you need to put that somewhere so it can read the air i believes its the IAT intake air tempertature or something like that sensor
Originally Posted by maximafrenzy
Ive never seen one of these hook ups b4, but isnt that a IAT sensor on top of the cone? That could be the problem doesnt it go inside the intake??
Originally Posted by LiGhtSoUt
you can either get a obd2 sensor or look in the stickies and pull the codes manual from the ecu and the screw but did you use a maf adapter or something else to hold it in ??
wats a odb2 sensor
WHAT THE HECK IS HE TALKING ABOUT?
IT'S A SCANNER LOL NOT A SENSOR. IT READS YOUR C.E.L AND GIVES YOU THE CODE.
wats a odb2 sensor
wats a odb2 sensor
wats a odb2 sensor
respect brother
and no i did not use a adapter i just pulled the metal adapter that was in my air box and hooked the cone filter to that but i think i m gonna need to do something else, cause today my filter came off my maf and scared the doodo outta me i thought i
my tranny
Originally Posted by raziq_afg
respect brother
my tranny
JoshG
51
Sep 21, 2015 10:41 PM
