Removing a dash kit
Old Jul 9, 2007 | 08:14 AM
chefmaurod's Avatar
Removing a dash kit
I have had my aluminum dash kit on for almost three years and its really starting to fade. Has anyone taken their dash kits off and if so, what is the best method? I am not sure if I am going to put a new kit on or if im going to paint it. Let me know what you have done or what you think I should do.
Old Jul 9, 2007 | 08:16 AM
hiren_patel_83's Avatar
if you want to keep it pop it out and paint it. More cost effective. If not switch to carbon fiber.
Old Jul 9, 2007 | 08:24 AM
chefmaurod's Avatar
My problem is I have popped it in and out a few times for random things and a couple of the pieces are cracking as well. Not a fan of the carbon fiber look though.
Old Jul 9, 2007 | 03:42 PM
chefmaurod's Avatar
After reading about some of these dash kits on ebay that are like the one i have, it seems that all they have is the 3m adhesive on them and you can almost peel them off if you start in one corner. That being said, I am sure its going to leave a bunch of sticky stuff all of the original dash. So, whats the best thing to remove adhesive from that kind of surface and what do you think of this as a potential new kit ?
http://cgi.ebay.com/ebaymotors/Nissa...QQcmdZViewItem
Old Jul 9, 2007 | 03:55 PM
lilaclucymaxima's Avatar
Team Ramrod
I would pick up a dash from a junkyard or something, then paint that. Then again, I wouldn't have gotten a dash kit in the first place.
Old Jul 9, 2007 | 04:14 PM
chefmaurod's Avatar
I didnt want to put a dash kit on either, but the previous owner did something to the interior and the original dash looked like it was stripped of its color, so something had to be done. Good idea though getting a dash from a junkyard.
Old Jul 10, 2007 | 05:48 AM
iceman82's Avatar
you can use some goo gone to take off the adhesive that is left
Old Jul 11, 2007 | 06:25 PM
maxboy325's Avatar
Let it sit in da sun then start to peel it summer so should be enough heat to soften then use some kind of adhesive remover
Old Jul 12, 2007 | 10:07 AM
erty67's Avatar
Decal Specialist
I've had my CF kit on for 6 years and I still like it Buying all the pieces from a junkyard may cost a bit. I say sand it and paint it.
Old Jul 12, 2007 | 05:58 PM
vofact's Avatar
try this,duplicolor has a ''metalcast'' silver paint that actually looks like metal,I almost went that way,but i decided to paint mine gold.I used the metalcast paint on my grill inserts. I think youll like it , it's an aluminum color and looks like metal
Old Jul 12, 2007 | 06:02 PM
KRRZ350's Avatar
I think you should buy my entire I30 oem woodgrain kit. Though the climate control trim wouldn't be the same for your '99
Old Jul 12, 2007 | 06:14 PM
2blue's Avatar
how much ?
Old Jul 13, 2007 | 05:51 AM
chefmaurod's Avatar
I am going to be taking the dash kit off on sunday. I will post an update on what the condition is underneath and will make a decision based off that. Thanks for all the suggestions.
Old Jul 15, 2007 | 05:20 PM
chefmaurod's Avatar
Well, I took of the kit today and the actual removal wasnt that bad. I let the car bake in the sun for awhile and then the individual pieces peeled right off. The problem was a decent amount of the adhesive remained. I peeled it all off with my fingers but the dash is still sticky. What is my best bet to get the dash completely clean ?
Old Jul 15, 2007 | 06:48 PM
Team Ramrod
Goo-off... maybe mineral spirits, but if you use that make sure you wipe it with water after.
Old Jul 20, 2007 | 06:26 PM
SoMarvelus's Avatar
exactly, i've got a red joint and there is no way i would paint it red...too rice!!
The Frye
Sep 2, 2021 11:03 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
BrandonCause
Sep 20, 2015 10:20 PM
