Axle problems..
Old Jul 10, 2007 | 07:58 PM
QnzMax's Avatar
Axle problems..
I was evening out the coilovers the other day and when I drove the car afterwards I heard the infamous clicking sound. The sound only happens when I step on the gas. At first I thought I just had to grease up the K-Sports but I found out it wasn't that after doing it. Next thing to suspect would be the axle, especially with the sound that comes from it. My question is: Is there supposed to be any play on the axle? I got under the car and tried to move the axle back and forth and it shifts a little bit. I did the same to the passenger side axle and that one didn't move. If the axle is shot then it's time for some Raxles.
Any help would be appreciated. Thanks
Old Jul 10, 2007 | 09:56 PM
Dexter's Avatar
usually it's the drivers side axle that goes out, it def looks like it's time for some raxles, my pair came in the mail today. Will put them in this weekend.
Old Jul 10, 2007 | 10:54 PM
maxima985spd
NOT FOR ME PASSY FOR ME
Old Jul 11, 2007 | 06:05 AM
Dexter's Avatar
That's why your better off shelling out for both of them, in case you were WRONG and the other one turned out to be done
Old Jul 11, 2007 | 08:14 AM
maxima985spd
the passenger side is a longer axle so when we lower our cars is fawks it up
Old Jul 11, 2007 | 07:37 PM
mikey chalupa's Avatar
I changed out my axles and lowered my Max and the suspension hasn't been right since. It's the passenger axle. I get alot of vibration in the pedal and what seems to be some sort of rubbing. It's all tied into the axles though.
Old Jul 11, 2007 | 08:09 PM
f550maranello2's Avatar
grab the axle and try to move it out of the trans and back in again.. .if there is any play..(other thank like 2mm) then it needs to be replaced
Old Jul 11, 2007 | 08:40 PM
QnzMax's Avatar
I did that and I would say there is more than 2mm of play. It moves enough where metal clanking is made. I was thinking of just getting the Raxles since I'll be be boosted again, as soon as I get my blower back from Vortech.
Old Jul 11, 2007 | 08:44 PM
if there is more than 2mm of play i would say its bad... it cant move too much
Old Jul 12, 2007 | 12:19 AM
maxpeed96plat.'s Avatar
QnzMax: make sure your axle bolt in ur hub is properly tightened, I'm not sure of what type of play ur talking about, but if car is lifted the axle will move slightly because of the up/down movement of susp.
Mikey: when ever I replace my axles, I always get an alligment. When removing lower bolts from strut and lowering- camb/cast needs adj for spec.
Old Jul 12, 2007 | 04:50 AM
I'm gonna tighten the axle bolt today. Do you think my vibration is coming from an alignment? The vibration is pretty bad. It's mostly in the pedal with and without load. I'm gonna check for play today. I don't think I have any though.
Old Jul 12, 2007 | 05:29 AM
the axle nut holds the hub tight against the knuckle and bearing...
but if the axle starts to get to loose the wheel will move around like that...
Old Jul 12, 2007 | 06:49 AM
97SEdriver's Avatar
this place is dead
make sure it isn't your tires being out of balance or something.....and as far as axle play..the passenger side is bolted to the car, the driver's side is just held in with a stupid ring clip.....the cause for much wasted MT-90......
Old Jul 12, 2007 | 07:05 AM
hiren_patel_83's Avatar
dang makes me rethink about lowering my car.
Old Jul 12, 2007 | 09:39 AM
yes allignment..if it's only in the pedal it could be brakes, check; rotors for warp, sticking piston, etc.
edit- balancing only if it was doing it before work was done
Old Jul 12, 2007 | 10:13 AM
QnzMax's Avatar
I think the problem is that the axle isn't in all the way. Somehow it came out and I need to put it back in. The same thing happened when the 5spd swap was first done.
Old Jul 12, 2007 | 02:50 PM
pmohr's Avatar
No more Maximas...
Are you auto or 5MT? If you grab it near the trans side, does it show a bit of free play?
Diff bearing issue is common on the A32's...
Old Jul 12, 2007 | 02:57 PM
ewuzh's Avatar
I normally get some very light dull axle clicking in the morning when the car is still cold. When it's warmed up, I have no noises at all. This is my second set of raxles (yay for warranty), so don't buy them thinking these are some type of magical axle that doesn't click or go bad.
Old Jul 12, 2007 | 08:32 PM
I'm gonna get an alignment. I already had the tires balanced. The guy told me that the tire may not be perfectly round, so I'm gonna switch the back wheels up front until my new tires come in. I figure I would replace them now.
I just replaced my rotors and pads about a month ago. I think I might have a sticking caliper. I slammed on the brakes to avoid hitting a cow and it hasn't been the same since. I think I'm gonna do the q45/cobra rotor upgrade.
Old Jul 13, 2007 | 11:09 AM
air_max's Avatar
How much did you pay for your including shipping, and where did you get them from?
My clicking is getting bad and i need to get to it soon!
Old Jul 13, 2007 | 08:43 PM
amkmax97's Avatar
Hi im new to org and i have had the same problem on my 97. Its been like three times since ive had to replace my passenger side axle to that problem and it kepps coming back. I see you got ksports, i have same setup but i believe its the fact of being too dropped. Some people have told me that everytime they hear it.
Old Jul 13, 2007 | 08:53 PM
S.S.Engine's Avatar
When you replicate that noise, can you give more detail on it?
Clicking would signify a CV issue.
Old Jul 14, 2007 | 04:50 AM
amkmax97's Avatar
the clicking sound is the cv joint but what would cause this to happen continuously. like mine has been changed three times and it just went out again.
Old Jul 14, 2007 | 07:04 PM
Dexter's Avatar
raxles.com shipping varies by location but total cost is a fraction of what it would cost to take it to the shop.
Old Jul 14, 2007 | 10:51 PM
How low is your car? suspension travel might b an issue, is there oil getting on ur boot- oil breaks down the rubber boot faster.
Old Jul 15, 2007 | 12:44 PM
amkmax97's Avatar
i dont know cause i never measured it but its low like qnzmax. i have 18s on now but before when i had the factory hubz with steelies my front bumper was 2 inches off the floor. i got the ksport adjustables. and no there is no oil leaks no rubber busted. I dont think there is much suspension travel cause i blew one strut already.
Old Jul 15, 2007 | 11:34 PM
You just answered ur own question, if ur blowing struts ur lowered like I am- I go through axles about 1 & 1/2 to 2 yrs and strut haven't had a prob yet. We're lowered enough to throw off the geometry that the suspension was designed for.
p.s.- you gotta pay to play, lowered looks good but requires bit more maintanance. Your gonna go through axles thats the price for the drop.
Old Jul 16, 2007 | 10:14 AM
maxima985spd
uuuummm NO
Old Jul 17, 2007 | 11:40 AM
amkmax97's Avatar
it cant be that i answered my own question cause the my first cv joint went out to make the clicking sound my car was at stock hight. At that time it was making the worst sound. I got some advice from a friend of mine that knows maxima from the back of his head and he told me that it could be that i need a wheel alignment.
Old Jul 18, 2007 | 12:22 AM
A wheel alignment issue would most likely cause more stress on bushings, endlinks, tie rods, etc. -> not so much on your axle. IMO axle damage most likely occurs from suspension travel and someone who drives car hard- on corners, off the line, high rev, etc. Do as u please, cause an allignement won't be bad for your car, just get the allignment done at a perf shop that can deal with lowered cars, most of the common allign shops go with factory specs this includes height- they don't really play to much with compensation of height etc.
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
