winny,squeeky noise..cant figure it out.
Old Jul 18, 2007 | 06:45 AM
96MaximuzGXE's Avatar
Ok so i start the car and after about a minute i get the winny noise comming from the driver side by my intake somewhere around there.Thought it was the belts but its not comming from that side.When i put the car in gear or reverse it gets worse...when i give on the can its fine but when i start braking it comes back and when the car idles.It sounds like the belts to me but its not.Any idea what it could be?
Old Jul 18, 2007 | 06:49 AM
Dexter's Avatar
Check your CV joints for tear, your ball joints and your tie-rods, you should find the cause there, in my case it was a combo of bad cv axles and bad tie rods, all better now.
Old Jul 18, 2007 | 07:00 AM
well i just had new complete axles put in and replaced all the old.also a new ball joint on that side...i still need a bushing and sway bar link kit(link kit on passenger side) wondering could that be it
Old Jul 18, 2007 | 08:02 AM
Dexter's Avatar
perhaps, in my case it was the tie rods which I never would have guessed had I not repaced my CV joints plus alot of shops tend to miss the ball valves and tie rods upon inspection, and just tell you you need new CV joints cuz it's more expensive to replace than tie rods $750 > $70
Old Jul 18, 2007 | 10:32 AM
97SEdriver's Avatar
this place is dead
Does this sound happen before you're moving? Does it happen when you're stationary?
If yes.....then it has nothing to do with CV joints, axles, tie rods, or anything at all related to the suspension.
Old Jul 18, 2007 | 05:23 PM
Yea when its idles and like i give it gas driving and its fine then when i brake is does it a little and when its idles in the driveway...sounds like belt needs to be greased or something but its from the drivers side.Does it when i go from park to reverse or drive...like a winning fan or belt.
Old Jul 18, 2007 | 06:07 PM
97SEdriver's Avatar
this place is dead
I'm going to guess it's an auto......?
Old Jul 19, 2007 | 09:27 AM
yeah its auto...which i hate but o well....but yea it does that is what happens
Old Jul 20, 2007 | 09:34 AM
Dexter's Avatar
check your rear brakes, it may sound like it's coming from the front when it could be coming from the back (i.e. warning clip on rear brakes) I just did my rear brakes and they were worn down to dust another month and they could have fux0red up my rotors.
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
fx4five
Oct 18, 2015 06:57 PM
09maxshawn11
Sep 30, 2015 10:28 AM
