rack&pinion bushings
Old Jul 18, 2007 | 07:02 PM
tlrmax's Avatar
How do you remove the rack and pinion bushings? Do I need to remove the rack? I looked under the car it seems I have to unbolt the front antisway bar to get to bottom bolts but I cant reach the top bolts. Also does anyone make replacement bushing for sway bar ends that bolt to the frame or lca I dont remember.
Old Jul 20, 2007 | 07:37 PM
tlrmax's Avatar
anybodyyyyy
Old Jul 21, 2007 | 06:38 AM
dgeesaman's Avatar
Maintenance Monster
Can't wait 35min for an answer?
You can get swaybar bushings from Nissan or urethane ones from Energy Suspension.
To change the rack bushing you'll need to unbolt a few things on the driver side and slide it out. On the passenger side you'll need to drop the y-pipe, remove a heat shield, and unbolt a few other things to slide it out on that side. If your steering is in question you might consider changing steering racks before you go thru all that work.
Old Jul 21, 2007 | 09:46 PM
madnut's Avatar
I have tried replacing mine, my driver side one fell apart so i bought 2 new ones.
The driver side is not super hard to replace but the passenger side is a friken pain i tried and decided i don't want to take apart half the car.
I would also recommend really considering if you need to change them.
Old Jul 22, 2007 | 08:01 AM
Kevlo911's Avatar
Kevlo for President
Yeah you can change them, I got mine from www.rockauto.com
Starrider
Dec 18, 2015 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
06maxima55
Sep 28, 2015 04:29 PM
