errr FING CAR
Old Jul 31, 2007 | 07:00 PM
MaxFanatik's Avatar
errr FING CAR
yesterday my car started to sputter and not hold idle and jsut stall out under 1000 rpm. After trying to get it to sa shop my car broke down tootally woudlnt start .5 miles from teh shop. After gettin to the shop i had 6 codes.... we fixed the issue with not starting a blew a fuse. Now i had an EGR code. the guy working on my car is prety fmailiar wiht max's and i30's. He said the egr valve staying open is a common problem and would give u the sypmptoms u have wont hold idle sputter and choke. After he cleareed all codes we ran the car for a fem mintues nottin came back.... besides a bank 4 missifre, coil died got a new one.
today driving to my gf's house tp philyl abotu 40 miles. rite as i get onto her block it doesnt hold the idle again. And sputter and die. I got the car home at nite, im pretty sure my EGR valve is ****ed up. How much is a EGR valve go for ?
Old Jul 31, 2007 | 07:12 PM
f550maranello2's Avatar
iv never seen an egr go bad on our cars....
its probably the EGR tube that is clogged solid...
check to see if ur getting vacuum to the EGR rubber hose that is attached to it..
then check to see if the valve actually opens under throttle....
VQrebuild96's Avatar
you know i really can't see how an egr is causing this... mine is completely off and it runs fine...
Old Jul 31, 2007 | 07:25 PM
ImmaSquashYou's Avatar
sounds like my car.....clean teh iacv n it'll be better.....but u might have to change it..n i was quoted from my dealer $150 for an egr...
Old Jul 31, 2007 | 09:00 PM
pmohr's Avatar
No more Maximas...
If the EGR were completely open at idle, then it could cause issues, but not if completely blocked up/clogged.
Old Jul 31, 2007 | 09:09 PM
'96 B-rad's Avatar
If it turns out to be the egr valve there about $100 heres a link for a site I use to order stuff from. http://www.trademotion.com/partlocat...layCatalogid=0 But you should try cleaning it first since they rarely go bad
Old Aug 1, 2007 | 08:31 AM
MaxFanatik's Avatar
Well good news its not an EGR....
Reason why EGR can cause this is if the valve is open, the extra exhaust gas go back into the intake system causing it to choke and sputter........
one of the tubes on the intake came Loose DOPEEEEEEE =[, fomr the previous time i wasa the shop when we were testing stuff.
And i didnt bother to look at it under the hood, couz it was doing the same **** as before, but before i had an EGR code.... i over paniced
SO LETS HOPE IM DONE WITH THIS... im tired of towing the car ****ing scratchign my muffler dueshbag almsot cracked my front bumper getting it on the bed.
Old Aug 1, 2007 | 11:47 AM
clive's Avatar
100% chingon
Yeah, agreed. My son's EGR is just a corroded lump and the tube isn't even connected but the damn thing seems faster than mine. Actually I think it's because I fixed the O2 sensor on mine and he hasn't.
Old Aug 1, 2007 | 12:32 PM
maximafrenzy's Avatar
Fuhget About It.....
Just a few suggestions, but have you checked your fuel pump, or filter? What about the plug in the bad coil pack, did you check all the spark plugs?
Old Aug 1, 2007 | 01:29 PM
MaxFanatik's Avatar
well if u guys unplug the egr, than it would be as if it is closed..... but when the egr valve is stuck open exhaust gases get escaped into the intake system.
fuel pump i didnt check it......
fuel filter was replaced not to long ago....
coil that went bad was bad.... we tested it
sparks were good......
I had an EGR code before on my old max, and it drove fine.....
Old Aug 1, 2007 | 01:31 PM
MaxFanatik's Avatar
I had the EGR code, IACV Something Code, and another valve code.... but after we got my car started up and my coil changed on monday, clear the codes they never came back....
and today at the shop no codes either.
freakin weird.
btw did uget a new egr? couz he did say he chanaged one on a i30 before, myabe it was urs its a shop in new brunswick of rt 27.
Old Aug 1, 2007 | 02:34 PM
nah.....i'm pretty sure its my iacv.....hopefully at least.....i'll change that n see what happens..at first i thought it was the maf..so i got a buddy of mine to ship out his extra...but when i was cleaning mine i broke it..so i went ot hte junkyard n got another one..only to find out it wasn't the maf....cleaned the iac....kind of better.but i think a need a new one......hopefully its not the tranny..otherwise....i'm getting a truck or g35....
Old Aug 1, 2007 | 04:47 PM
MaxFanatik's Avatar
i dont think the tranny will cause u to chocke out.....
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
