Told that my engine is going to fall out?
Old Aug 16, 2007 | 07:49 PM
timmyp34's Avatar
hey i took my car into a shop to get a service and they phoned back saying that my car is to dangerous because the engine is going to fall out? i think it is utter ball****
The car only has 93 miles on it if is is true what could it be?
Old Aug 16, 2007 | 08:04 PM
Mxrider52's Avatar
I support for what?
You mean 93K? Also if they are saying your engine is going to fall out your radiator support could be rusted out which connects the crossmember that holds up your engine. If that is rusted out the the chance of your engine falling out is greatly increased.
Old Aug 16, 2007 | 08:09 PM
timmyp34's Avatar
no its 150,000kms(93 miles)which isnt to high over here in nz.
ok i all go have a look for rust around the radiator. is there any other signs? how do you check that the engine mounts are working probliy?
thanks for the help
Old Aug 16, 2007 | 08:34 PM
sachmo's Avatar
Could you provide some pics of what this support is. On my 95 if you look through the lowest grill you see what looks like a part of the frame that is rusted extremely bad. Please provide further info because I might have this a a potential danger also.
Old Aug 16, 2007 | 08:37 PM
timmyp34's Avatar
ok i will take some pictures when i go down my self and look at it
Old Aug 16, 2007 | 08:53 PM
matty's Avatar
Just get underneath the car and take a look at the support that runs underneath the Radiator that connects to the cross memeber and both side of the vehicle. Its a comman place to find rust on older maximas and most likely will have to be replaced which entailes cutting out the old rusted section and welding in a new lower peice that nissan does sell.
-matt
Snypa's Avatar
yeah,take some pics mann.
Old Aug 16, 2007 | 10:59 PM
maxpeed96plat.'s Avatar
http://forums.maxima.org/showthread.php?t=500698
This may help some of you.
Old Aug 16, 2007 | 11:16 PM
timmyp34's Avatar
turns out that they where not all sh*t the bit where the front cross members get bolted to the front has cracked...i am thinking about jacking the bit where it was bent don into place then welding it back on
do youthink that would work?
thanks on the link and help guys
Old Aug 17, 2007 | 01:04 AM
matty's Avatar
Cant really bent rust back and weld rust....depending on how bad it is.
Might just be better to add some metal support across the car and weld it as best as you can, if you dont want to replace the lower peice that is.
-matt
Old Aug 17, 2007 | 03:19 AM
timmyp34's Avatar
its not rust it has jst cracked if i jack it up to where it whould be a weld it and maybe but some more steel in it. i think it is worth a shot i CBF pulling the cross member out etc etc and plus it wont cost me anything to fix.
i am not losing out on trying anyway
Old Aug 17, 2007 | 04:00 AM
jman7777's Avatar
thanks for the help
150,000kms = 93k miles. If your car had 93 miles on it...
Old Aug 17, 2007 | 04:07 AM
XJinCT's Avatar
<3's the all motor section
even if the front mount rusts through...it will NOT fall out.. its physically impossible.
Old Aug 17, 2007 | 08:56 AM
alcatranz518's Avatar
I agree, Mine broke completely and I even welded in metal as a temp fix. It WILL NOT fall out, but it will clunk and make other noises while turning or hitting bumps. Its still unsafe no matter how you look at it though and still is wise to fix. Its not too hard to do yourself. I fixed it in a weekend the right way and it cost me about $200 total for parts and supplies.
Old Aug 17, 2007 | 10:21 AM
sachmo's Avatar
Just went out and took pics.
FIxed for ya, kevlo911
Old Aug 17, 2007 | 10:36 AM
It isn't horrible yet, but one good ol' Ohio winter and it will be!
Old Aug 17, 2007 | 11:10 AM
BLACKonBLACK98's Avatar
Former Vendor
never seen a car get rusty in 93 miles. fix it right and fix it once.
Old Aug 17, 2007 | 01:41 PM
XJinCT's Avatar
hah thats not nearly as bad as mine, or the other 2 maximas i have.
Old Aug 17, 2007 | 03:42 PM
f550maranello2's Avatar
a co-worker took his car to Nissan and complained about it today since his is getting pretty bad... hes getting a word back tomorrow to see whats gonna happen... funny thing is that they didn't laugh in his face or anything they actually got on the phone with corporate and he might get it done for free...
Old Aug 18, 2007 | 10:02 AM
Morpheus2010's Avatar
Nissan corporate might do his radiator support for free? let us know so we can call about it.
Old Aug 18, 2007 | 10:31 AM
HomerMAC's Avatar
Donating i30 Owner
seriously.. i think every member in snow states has this problem... it would be nice if they fixed it.... as it is a common problem.
Old Aug 18, 2007 | 10:51 AM
Nopike's Avatar
I also have this problem with the radiator core support rusting out on my 1998 Maxima. I called corporate and expect a call back soon. This problem is due to a bad design and can also be a safety issue as your engine will shift and may be damaged if the two bolts holding the cross member to the core support fail. I would suggest every one who has a Maxima with this problem contact Nissan, perhaps if we get enough people pointing out this design and saftey hazard Nissan may provide some compensation. This is not normal wear and tear of a car.
Nissan Consumer Affairs
P.O. Box 685003
Franklin TN 37068-5003
(800) NISSAN-1 (or 800-647-7261)
8:00 a.m. - 5:00 p.m.,
Eastern / Central Time / Pacific Time
Monday through Friday
Old Aug 18, 2007 | 03:38 PM
timmyp34's Avatar
Some how o dont think nissan dealers will pay out over here
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
seesole
Sep 14, 2015 12:38 PM
jwright36
Sep 8, 2015 11:45 AM
