Whine under the hood..another one?
Old Aug 23, 2007 | 06:57 AM
eclypsecl's Avatar
I get an almost whinning sound under the hood increases if I rev the engine, not the alternator or anything on the left hand side..it almost seems like it's coming from the throttle body area. When I put my hand on it and rev the engine there's a whooshing and high pitched smooth whine coming from around that area.. any ideas?
If it's the hoses where can I get replacement hoses, they're all different sizes!
Old Aug 23, 2007 | 01:12 PM
eclypsecl's Avatar
Now I'm getting an 0201 code with a 0401 ...a little lost at what this compounded with the whining sound from under the hood could mean, any ideas?
Old Aug 23, 2007 | 01:16 PM
maxima985spd
Fix those CELS
Old Aug 23, 2007 | 01:36 PM
eclypsecl's Avatar
good idea...where do I start???
Old Aug 23, 2007 | 01:56 PM
maxima985spd
In the Stickies:
http://forums.maxima.org/showthread.php?t=104931
Old Aug 23, 2007 | 02:01 PM
eclypsecl's Avatar
the codes don't make sense...they started after coil pack died, i replaced it. O2 code popped up..now it's gone..0401 came up..0201 is to coil pack..but doesn't say which one.
Old Aug 23, 2007 | 02:57 PM
maxima985spd
replace all the coil packs
Old Aug 23, 2007 | 10:19 PM
maxpeed96plat.'s Avatar
Get a volt meter select ohms and measure resistance between terminal, resistance values are in stickies for coils and o2 sensor u gotta search--> don't go changing parts that are fine.
Old Aug 24, 2007 | 06:13 AM
Big EEEE's Avatar
Check the coil packs with a meter as stated earlier. Keep in mind a good volt/ohm meter is cheaper than a coil pack !!! I have experience the coil packs on the back side failing more often for some reason.
Old Aug 24, 2007 | 06:21 AM
eclypsecl's Avatar
Regarding the whine, I can't hear it near the alternator..I hear it on top of the engine near what looks like evap system, but can't seem to find any holes in the tubing. Could this all be related? I also noticed my lights are very dim, every time I rev the engine they get much brighter...so my alternator is going too?
Old Aug 24, 2007 | 06:36 AM
Big EEEE's Avatar
What is your system voltage: car off, car on, lights on, a/c on?
Old Aug 24, 2007 | 06:45 AM
eclypsecl's Avatar
I'm going to get the volt/ohm meter tonight and test.
Old Nov 1, 2007 | 09:35 AM
eclypsecl's Avatar
A newbie question, how do I test the coil pack with a volt meter..I have a positive and negative on the voltmeter..and only the place where the spark comes out in the coil pack....do I just read that tip?
James92SE
142
Jan 2, 2024 09:23 AM
CorollaULEV
30
Aug 9, 2021 08:11 PM
homewrecker
Sep 24, 2015 07:01 PM
Andy29
Aug 31, 2015 01:59 PM
ngthing
Jul 6, 2001 04:19 AM
