2" drop, now problems
Old Aug 25, 2007 | 01:10 AM
got_max's Avatar
Wants a real car
Hey Guys,
Well like the title says, I installed Sprint Springs, 2" drop all around, and the installations went quite well, minus the fact that it sucks not having an impact wrench for my giant spring compressors.
Anyways, after everything was set up. I go for a quick drive, and notice. when ever I corner to the right, this metal vibrating, grinding, rubbing noise comes from the passenger front wheel. I took it off and everything seems fine, everything has sufficiant clearance.
Also the ride is a little harsher, with stiffer springs, but the steering wheel vibrated alot, I know this may be because of alignment issues. I am going tommorrow to get it alligned. If any of you guys have ever had this problem, or have any suggestions, please let me know.
Old Aug 25, 2007 | 02:39 AM
Bonka's Avatar
Schnell kaputt
Check if you bent the brakedust cover. Also re-tighten everything especially the center bolt on the strut. I have a similiar sound and also only happens turning/cornering right. It's likely that my axle is on its way out because of the drop. Might be that.
Old Aug 25, 2007 | 06:49 AM
67whitegoat's Avatar
What spring and strut set-up did you go with?
What size wheels and tires are you running?
Old Aug 25, 2007 | 07:40 AM
got_max's Avatar
Wants a real car
Stock wheelse. the honeycomb 15" GLE wheels. I have Tokico Illuminas all around, and I just put on Sprint Springs with a 2" drop all around.
Old Aug 25, 2007 | 09:04 AM
BLACKonBLACK98's Avatar
Former Vendor
did you make sure the springs were seated correctly and did you use isolators?
Old Aug 25, 2007 | 10:27 AM
BlackCat's Avatar
RIP '98 Maxima SE
Are the top parts of the coil wrapped like this? The top coils when compressed will rub against each other. See the slight rust stain on the black Eibach coil? That came from the upper coil.
I got the wrap from the electrical aisle of Home Depot.
Old Aug 25, 2007 | 11:08 AM
I agree with Bonka. My first thought would be brake dustshield. Put the car on jack stands, spin up the wheels and see if you can duplicate the noise.
Old Aug 25, 2007 | 12:12 PM
got_max's Avatar
Wants a real car
hmmm yea. It sounds like it could be the dust shield. Im going to check it out. But the noise only occurs when Im am cornering harder. ie. over 30. I am using the isolaters. but never thought of what black cat suggested there. Probably a good idea. When I get off work I willl take another look and update
Old Sep 13, 2007 | 05:25 PM
96ItaliaSE's Avatar
il massimi bassi
think you gotta wait till u get it aligned. With no other issues I have stech's with a 17x8 wheel and 225 50 tires and i dont rub at all. Tune your struts down to a lower setting and run a tire thats a tad thicker to clean up that stiff ride.
then again I Just finished installing new inner and outer tie rods, rack boots, bushings, balljoints, a cv axle, sway links with all factory nissan parts after I let a .org member work on it ...let just say he hacked it up pretty darn good
Old Sep 13, 2007 | 06:50 PM
MOHFpro90's Avatar
I find it hard to believe its the dust shield. Not that its definitely not, but if it only happens when you turn right? The rotor shouldn't move in relation to the shield when turning. If it does, you have bigger issues...
Old Sep 14, 2007 | 09:51 AM
Maximeltman's Avatar
sounds like CV joint by the passenger hub...
Old Sep 14, 2007 | 10:02 PM
Revs2Hard's Avatar
BARF
Could be a wheel bearing we see that alot at my work. We lower a car and the added stress on the old bearing makes it start to vibrate or make noise. It also could be a bad tie rod end or ball joint, for the same reason. Jack the car up and shake the wheel side to side, if there is play its ether a ball joint or tie rod end. Then shake it up and down if there is play there then its a bearing.
Just a suggestion.
Old Sep 14, 2007 | 10:32 PM
got_max's Avatar
Wants a real car
yea, well most of the problems got fixed, it was the dust sheild. the springs are SLOWLY settling and "weakening" a little. but everytime I hit a bump-. the springs are stiff and my car doesnt feel like it wants to take the pot holes anymore.
anyways, its all worked out. *for any noobs like me, * when re-installing the strut housings. make sure the top piece of metal is the right way. it says in and out on it. this was one mistake I made and almost destroyed my suspension. the spring almost popped right out of the housing
Old Sep 15, 2007 | 08:39 AM
maxprivate's Avatar
Black Lion
sprint springs
i have been riding on sprint springs for years on kyb agx front and koni in rear. no noise problems at all. yeah the ride is stiffer but its a sacrifice you have to take dropping your car. rides hard over bumps to, especially with "19 rims. at least you figuered out your problem.definitely get it aligned right away or you will destroy your tires quickly.
Old Sep 15, 2007 | 04:20 PM
SupraSonic's Avatar
I also have sprint springs on my max, but i'm ready to get rid of them. I have kyb's up front but they aren't the agx's and I can't go on hardly any roads unless they are smooth, because when the fronts bottom out, they bottom out real hard and harsh. It's starting to annoy me. Will it ride better up front with the agx's? If so, i'm willing to try them before getting rid of the springs. Thanks in advance!
Old Sep 15, 2007 | 08:01 PM
z32drifter's Avatar
Don't waste your money on new struts. If you want a big drop on an A32 go with coilovers. All the 2"+ drops put you almost on the bump stops. I'm on S-techs and AGXs and wish I had stepped up for coilovers.
Old Sep 15, 2007 | 09:29 PM
SupraSonic's Avatar
Thanks! It looks like I'll invest in some coilovers.
Old Sep 15, 2007 | 09:41 PM
G4nismo's Avatar
can your supra travel through time?
nice supra
Old Sep 15, 2007 | 09:58 PM
SupraSonic's Avatar
nice supra
Only if I turn on the flux capacitor.
Thanks for the compliment.
Old Sep 15, 2007 | 11:22 PM
97MaximaSE97's Avatar
Hey gotmax if its not too much trouble could you take a pic of how much travel you have before the bumpstops in the front and rear?
shilov
Feb 19, 2024 09:40 PM
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
slowlifer
Sep 8, 2015 05:53 AM
