Write up on how to change atf?
Old 08-28-2007 | 08:52 AM
bkmax98's Avatar
Does anyone have a write up on how to change the atf? I can't seem to find it in the how to section.
Old 08-28-2007 | 08:58 AM
dmBK's Avatar
How 'bout them cliffs?
Pretty much the same way you would change oil - Auto tranny has a pan, and there is a nut at the bottom. Undo the nut, let the ATF drain (5-10 minutes). Screw the nut back, and pour new ATF through the transmission's measuring dipstic tube. After 4 quarts, measure the level, and add more if needed. After, put the dipstic, in, start the car. If the wheels are off the ground, shift up and down through all the gears several times; if the wheels are on the ground, put the hand brake on, and perform the same steps. When done, put it in Park, keep the engine running, and check the ATF level again. Add more as needed.
Old 08-28-2007 | 11:03 AM
gen4maxima536's Avatar
look in the fluids section, there is a whole sticky about it with different ways to go about it.
Old 08-29-2007 | 11:08 PM
bkmax98's Avatar
thank you fellas
hcarter1112
42
07-18-2022 04:35 PM
gavin68
09-18-2021 01:36 PM
06-06-2017 03:01 PM
Need help
23
10-02-2015 09:56 AM
Noela
09-26-2015 09:22 AM
