cruise control problems
Old Aug 29, 2007 | 11:02 PM
albo's Avatar
this is the deal. have a 95 maxima, the other day on highway i was trying to cruise the button turns on ... with no problems but when im trying to press on the buttons on the stearing wheel it doesnt work... i tried several times to make it work pressig on different area of the buttons, but nothing. that same night i realized that the lights of those same buttons did not turn on..
any ideas or suggestions on how to fix this.
thanks before hand...
Old Aug 30, 2007 | 09:36 PM
albo's Avatar
anyone have any deas?
Old Aug 30, 2007 | 10:01 PM
DennisMik's Avatar
When you say the button turns on, do you mean the button on the dashboard lights up when you press it? If yes, then try holding the brake pedal up with your foot when you press the set button in the steering wheel. Does cruise control engage? If it does, adjust the switch on the brake pedal.
Old Aug 31, 2007 | 07:04 AM
packerZ's Avatar
try post above, if NOT the problem... replace the vacuum solenoid that mounts on the upper firewall (part # ??). It is mounted with two bolts reached from inner fenderwell with tires turned in- simple disconnect/re-connect one vacuum line and one electrical clip. If your car has over 125K it is a normal replacement item (about $30 online).
Old Aug 31, 2007 | 04:54 PM
albo's Avatar
ok i m lost with this explination... is there is a way you can say this in a more english way? like where its at in the car or hood or maybe an pic that would work
thanks
Old Aug 31, 2007 | 05:02 PM
IlyaK's Avatar
The Golden One
There are no lights on the steering wheel switches. Only on the dashboard one.
Second of all...try un-plugging and plugging in the cruise computer under the dash near your right knee cap. That worked on my 99. Otherwise...you'll have to test the relay, the vaccum pump...and a bunch of other stuff. This probably is no fun to fix. If you don't have a haynes manual...get one.
Old Sep 1, 2007 | 12:13 AM
ROCKART's Avatar
wants an I35
why couldnt it be as simple as a connection loss to the steering wheel. its just the buttons that dont work right? could just be a loose wire or joint
Old Sep 1, 2007 | 02:44 AM
Garrick's Avatar
We'll never know until he reports back. I have the same problem. I'm thinking solenoid.
Old Sep 1, 2007 | 08:05 AM
f550maranello2's Avatar
guys cruise control is fairly easy to check.. just takes a lot of time.. i had a problem when i pressed the button the light on the dash would just blink...
get a FSM haynes will not tell yea ****... The FSM will give you a great procedure on how to troubleshoot it....
Old Sep 1, 2007 | 08:16 AM
67whitegoat's Avatar
I would first check for a vacuum leak.
Old Sep 1, 2007 | 11:25 AM
albo's Avatar
il chek out those sugestions this week end.. if im able to and . give you guys some feedback and see waht happend...
i guess also going to try to get an manuel to check that out..
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
slowlifer
Sep 8, 2015 05:53 AM
