anybody running 17x7.5 wheels at a +45 offset?
Old Sep 4, 2007 | 01:45 PM
enomik-1's Avatar
I'm looking into buying some wheels from a fellow orger.
The wheels I'm looking at are Kosei K1 17x7.5 and the offset is +45. I was once riding on Volks 18x7.5 and the offset on those was +40. So my question here is if there's gonna be a big difference. I loved the way my volks sat under my fender but I wanna make sure that the +45 offset isn't gonna be too far inside the fender. Please I really need to make up my mind quick and Ive been surfin through the org doing research but I cant really do much here at work. Below is my old setup 18x7.5 @ +40 offset, tell me if you think it will look something like that or if the difference is gonna be noticable. Also If your riding on 17x7.5 with a +45 offset please post pics. Thanks, help is really appreciated. Thanks again everyone.
Old Sep 4, 2007 | 01:56 PM
max95q's Avatar
That car looks familiar. Who did you buy it from? I remember it being for sale some time ago from someone else. Anyway, if you like the +40 offset Id stick with that. I have 17x7's with 235/45/17 tires. I believe mine are +45 and I want some spacers to have them be like the +40 offset.
Old Sep 4, 2007 | 02:36 PM
VIP Maxima
it IS going to sit in more. i have 19x8 with 45 offset and it sits in quiet alot. spacers can fix the issue
Old Sep 4, 2007 | 03:56 PM
Fast1one's Avatar
Your probably not going to notice it much, its 5mm, but I would look for something else with a MUCH lower offset, around +25 for a 7.5 inch wheel...
Old Sep 4, 2007 | 05:36 PM
enomik-1's Avatar
I was trying to sale it a while back but after a deal fell through i realized i wanted to keep it. I love my max.
Yours looks damn good actually but then again, you have an 8 inch width to your advantage.
That's what i was thinking. Its a damn good deal that's the only reason why I'm considering. I really love the look of the Kosei K1's and i figured it would be a good jump start get it back to tip top shape again.
Does anybody know what the width and offset is to the 17inch 2k Max Se Wheels? I was running those for a while, that's actually what I'm rolling on right now. If it looks something like that I definitely wouldn't mind getting em.
Old Sep 4, 2007 | 06:47 PM
WhiteA32's Avatar
The stock 17s should be around 40/45
Old Sep 4, 2007 | 06:59 PM
max95q's Avatar
Good thing you kept it. Car still looking good.
Old Sep 4, 2007 | 07:03 PM
96blkonblkse's Avatar
stock 17's are 17x7 + 40
I had 17x7 +40 and with 235/45/17 and it sat pretty flush in the fronts. rear was hard to tell because my wheels didnt sit even (had re-center the rear beam). Since then i upgraded to 17x8 +40 and it didnt change. Ideally i think you want to run maybe a 10mm spacer in the rear. Im fine with mine, cuz i am going to be pretty low once i get my coilovers.
Old Sep 4, 2007 | 07:20 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Are these what your are looking at? If so Id stick with your Volks, they look much better and have a better offset.
Old Sep 4, 2007 | 07:59 PM
maxima985spd
in sig we got 17 x 7 45mm off
Old Sep 5, 2007 | 11:16 AM
enomik-1's Avatar
Cool, thanks. So being that the OEM SE wheels are 17x7 @ 40mm offset and the K1's are 17x7.5 @ 45mm offset, do think its safe to say it will almost look the same since the kosie's are .5inch wider? If that's the case, I wouldn't mind getting em.
Thanks man, it don't look like that no more. I made the mistake of selling the Ksports and my Volks thinking I was gonna trad in the max. It don't look too bad right now that's why I'm trying to start tuning again. I'm not too far off from where it used to be.
I sold em a while back. I've been trying to get something forged or at least light. Its gonna be hard for me to get something like volks again. So for now I want something good, light in weight, and nice. So it was either between the 5Zigen FNO1R's or these Kosei K1's. I found the K1's for a good deal but the offset is +45.
The pic in your sig is running 17x7 45mm offset? That don't look bad at all. you got anymore pics of that setup?
Old Sep 5, 2007 | 04:03 PM
hey man use this.
http://www.rims-n-tires.com/rt_specs.jsp
compare, according to that there was no difference between running 17x7 +40 and 17x8 +40 other then the width of the wheel, which is what i figured too.
In your case, i they will stick in a little more then the oem 17x7's would. but that can easily be fixed with a spacer. 5mm in the front, should bring you flush, and a 20mm in the rear should bring you just about flush. Depends on your drop though, if your really low flush will rub or require you to roll your fender.
Old Sep 6, 2007 | 11:17 AM
enomik-1's Avatar
Originally Posted by 96blkonblkse
hey man use this.
Thanks man, this really helped alot.
So i guess I'll go ahead ask one last question.
Would you guys buy a set of 17x7.5 wheels
@ +45. offset? Considering the fact that they
are in excellent condition and that they're
expensive wheels new and your getting them
for a good deal, plus the Fact that they are rare
and now discontinued. I only ask because I'm not
the type to use spacers, i dont wanna deal with
having to change out the studs and all that stuff.
so if i do end up buying these they will be goin on
the max with out spacers. So without spacers do
y'all think it would look good? I love these wheels
and i know there worth alot so i really wanna get
em but that +45 offset is really my only concern.
i just wanna make sure it looks like it belongs on
the car, I'll be throwing some new 235/45 tires on
there soon so just wondering what everyone thinks.
I'm currently sitting on Tein S.Techs and I'm saving
for some Ksports, so I will be slammed pretty
soon. please let me know what y'all think. I must
make my decision today. Thanks again everyone.
Old Sep 6, 2007 | 11:38 AM
Vlasic's Avatar
I might buy them to sell, but I probably wouldnt run them on my car. I dont like using spacers either, I want the offset to be just right. Also, 235 tires are too big for 7.5 rims, Id use 225 MAX, but even 225's are going to buldge out a little bit.
Old Sep 6, 2007 | 11:52 AM
I had 225's on my 17x7's and it was fine, the sidewall was straight not bulged or stretched. (michelin pilot sport a/s)
Well most people dont buy staggered setups, because the only way your going to get flush in both the front and rear is to go with different offsets, and sometimes that requires going with a wider/thinner wheel in the back to get the correct offset. but you already no that, but some people may not.
Old Sep 6, 2007 | 12:04 PM
maxima985spd
17 x 7 i know for a fact. (tires are 215/50-17) i know the offset is pretty high i know it isnt 40. im pretty sure it's 44 or 45. this car is also lowered like 3 inches...
Old Sep 6, 2007 | 12:11 PM
Maximus_95's Avatar
45 offset is going to be a big difference on the rear..... i had them and did not like it much...
Old Sep 6, 2007 | 09:10 PM
enomik-1's Avatar
high i know it isn't 40. I'm pretty sure it's 44 or
Thanks so much man. If that's what +45 offset
looks like then i wouldn't mind getting them.
i think it don't look bad at all.
My mind has always been set on 2 wheels.
Kosie K1's
and the 5zigen Fno1's
I knew the K1's in the anthracite color was discontinued so i was
leading towards the 5Zigen FNO1 hyper black. but then i found these
for a real good price that's why I'm considering them so hard. any last
suggestion from anyone?
Old Sep 6, 2007 | 09:32 PM
gtr_rider's Avatar
192.168.1.1
Ygpm...
Old Sep 6, 2007 | 09:37 PM
Nealoc187's Avatar
SLOW
you can't compare offsets directly if the wheels are different widths ... a 7.5" wheel with a 45mm offset is going to stick out 1/4" further than a 7.0" wheel with a 45mm offset.
there's my 7.5" K1s w/ 45mm offset. I wish I'd gone with the 35mm offset (like 38 would've been perfect).
Old Sep 6, 2007 | 09:40 PM
Nealoc187's Avatar
SLOW
here's another - those tires are 235-40s I believe at that time.
Old Apr 8, 2008 | 11:24 AM
sil SE's Avatar
enomik-1 , did you end up buying those wheels with the +45 offset?
im looking at a set of 17x7.5 +45 right now and probably going to wrap them in 225/45/17.
its been at least 4 years since i've purchased new rims for my last maxima. doing some new research on what others have done.
thanks
Old Apr 8, 2008 | 12:09 PM
WhiteA32's Avatar
You realize that you just brought back a 7 month old thread right?
Well here is your answer: Yes the rims will fit fine...
Old Apr 10, 2008 | 09:04 AM
sil SE's Avatar
thank you for your answer, i do appreciate it. but of course i brought i know it's an old thread- i SEARCHED. i don't think it would be so hot if i started a new thread on this.
are old threads only supposed to stay dead ?
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
Garrettz459
Aug 29, 2015 02:18 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
twotonezed
Aug 16, 2015 11:41 AM
