alternator installation?
Old Aug 5, 2001 | 08:56 AM
cwilsun
I am considering installing an alternator on my 97 maxima. Do you pull the radiator to get to it? this seems to be the most logical because the compressor is under the alternator. I any one has done this and would like to pass on some advice, it will be greatly appreciated.
Thanks,
Chad
Old Aug 5, 2001 | 08:58 AM
Eric L.'s Avatar
Yes, you have to drop the compressor to get to the alternator. You don't have to remove the radiator though.
Old Aug 5, 2001 | 09:01 AM
Daniel B. Martin's Avatar
Thanks,
Chad
Replacing the alternator is a job which may be done by the home mechanic. It is not especially difficult but will be time consuming. You will need a floor jack, a set of sturdy jackstands, and an assortment of common hand tools.
1) Make a written record of the radio station presets.
2) Disconnect the negative terminal of the battery.
3) Raise the vehicle and support it on jackstands.
4) Remove the two plastic splash shields which interfere with access to the alternator.
5) Loosen the drive belt idler (tensioner) pulley and then remove the drive belt.
6) Remove the A/C compressor mounting bolts. There are four of these bolts.
7) Remove the cooling fan and fan shroud.
8) Slide the A/C compressor forward.
9) Disconnect the alternator harness connector.
10) Remove the alternator upper bolt and lower bolt.
11) Remove the alternator from the vehicle.
Installation is the reverse of the removal procedure. As the final step, use the notes made in step 1 to restore the radio station presets. Set the clock to the correct time.
DJLAX152
May 4, 2021 11:46 AM
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
