braking = steering wheel vibration
Old Aug 9, 2001 | 09:49 PM
danny's_max's Avatar
My problem is, when I step on the brakes at high speeds (70+), my steering wheel vibrates pretty bad, to the point where I can actually see it shaking up. I'm guessing that my rotors are warped or uneven. I had them resurfaced twice, I guess its time to get some new rotors. What are your inputs on this. Thanks. Another problem is, I've been getting a lot of steering vibrations at idle lately. I have a '98 GXE and just recently changed the fuel filter. But the steering vibrations happened before I changed the filter. RPM seems to be at normal: 550 RPM. And this happened a few times: when stopped at a light, my idle dropped to around 250-300 RPM, causing the car to all shake up. Seems strange especially when I have only about 33,500 miles. Any help will be much appreciated. Thanks.
Old Aug 10, 2001 | 12:07 AM
maxmonkey's Avatar
alignment problem?
i've had this problem too before fixing my alignment. since u cut ur rotors already i don't it's coming from your braking system.
Old Aug 10, 2001 | 12:09 AM
mk dema
Re: alignment problem?
I've had that problem aswell when I tap on the brakes at 70+ MPH, I think it's the brakes because when I had my brakes changed in the front it went away, but as with any front wheel drive car, there will be a little bit of vibration in the steering wheel when you brake at high speeds. As far as the RPMs dropping, you should take it to shop and have them clean your fuel injectors, I noticed that the rpms are more stable after I had mine cleaned. Not sure if that's the solution but you might as well give it a shot.
Goodluck getting the problem fixed
Old Aug 10, 2001 | 04:13 AM
Daniel B. Martin's Avatar
Originally posted by danny's_max
My problem is, when I step on the brakes at high speeds (70+), my steering wheel vibrates pretty bad, to the point where I can actually see it shaking up. I'm guessing that my rotors are warped or uneven. ...
If you feel a pulsation in the brake pedal the rotors may be at fault. If no pulsation, the problem may be a tire defect such as tread ply separation. Please rotate your tires, exchanging fronts with rears. If the symptom vanishes, the brakes are not at fault.
Old Aug 10, 2001 | 07:31 AM
riggy's Avatar
Re: Re: alignment problem?
when i first test drove my car the vibration thing happened when i braked period, not necc at high speeds. the toyota dealer told me it was the break pads bec "the car did not have nissan break pads" is what he told me. anyway, he did get it fixed.....im not giving advice since i dont knwo anything, just sharing an experience so it may help....later.
Old Aug 10, 2001 | 08:27 AM
mzmtg's Avatar
Minister of Silly Walks
...but as with any front wheel drive car, there will be a little bit of vibration in the steering wheel when you brake at high speeds.
Not true. With everything in proper working order there shoudl be no vibration in the wheel. FWD has nothing to do with it.
Old Aug 10, 2001 | 11:02 AM
Re: Re: Re: alignment problem?
I agree. Plain Jane (my '99 GXE) exhibits no braking vibration at all.
Old Aug 10, 2001 | 09:02 PM
I do feel a little pulse whenever I step on the brakes. So it must be the rotors are gone! Already resurfaced twice, I dont think its worth it to do it again. Probably better thing to do it get some new rotors.
lowpost99
Oct 26, 2025 06:53 PM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
coasterswim
Sep 2, 2015 07:43 AM
