Addco RSB...
Old Aug 19, 2001 | 04:27 AM
apexi's Avatar
is it just me or did anyone else have trouble fitting the brackets on? not the 2 "U" shaped ones but the square ones???
Please help!
Old Aug 19, 2001 | 04:47 AM
bobl's Avatar
Square brackets
Please help!
Yes, you have to remove the screw holding the brake line. Once you do that it's easy. If you don't.. good luck!
Old Aug 19, 2001 | 06:03 AM
Mishmosh's Avatar
Please help!
Also keep in mind that the plates that the brackets screw on to are different. If you put the plates meant for the side arms onto the axle bracket, it will fit, but the plates meant for the the axle will just barely NOT fit for the side arm brackets. Just switch the plates around. They look the same if you are not careful but the spacing of the holes is different. Check it out...
Old Aug 20, 2001 | 04:48 AM
apexi's Avatar
thanks...n/m
n/m
maxleaner
Jun 21, 2001 10:39 PM
RBa
Jun 10, 2001 06:31 AM
Max 1109
May 6, 2001 04:29 AM
Cattman
18
Apr 5, 2001 08:45 AM
TexMaximum
Nov 23, 2000 03:50 PM
