My M/T is leaking
My cars been up on jackstands for the past few days as I'm redoing my exhaust system. I degreased my engine and I noticed my transmission has a slow leak. I have pinpointed the leak to (I dont know the proper terminology) this black roundish unit that has a cable coming out of it. Anyway, I'm considering what is the best way to take care of this leak. I'm thinking to drain the M/T fluid (it was changed only 5,000 miles ago and is synthetic) into a clean container, and then using RTV or a similar gasket maker. Or, I will see if replacing the gasket on the "black roundish unit" is feasible.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
I had a slow leak from my tranny as well, and it order to fix it, the damn thing needed to be rebuilt, apparently there are seals on the inside of the tranny that you can't replace without cracking the thing open. I couldn't pin point where my leak was coming from so you may have something different wrong. Mine was on a 96
Not sure if this helps you in anyway but just a thought
Originally posted by emax95
The black roundish thing is probably your reverse cable thingy. Best way to describe it
. I am sure there is a seal or a bolt that can be tightened. I bet D.B.M. knows all about it.
The PNP switch is secured to the transmission case with one bolt. There is an O-ring behind the black plastic part which you can see, and perhaps that O-ring should be replaced.
If you remove the PNP switch all the gear lube will come out, so be ready with a catch pan. Some Maxima 5-speed owners prefer to use the PNP switch as a drain plug because the "official" drain plug is difficult to reach. What's more, the factory makes drain plugs far too tight.
Originally posted by Neptune97
I also recently put synthetic M/T fluid in my car, and while I was reading up on the benefits of it, I noticed that several people developed a very small leak like the one you described (not necessarily at the Park Neutral sensor) once they started using synthetic...it might just be the viscosity of the oil, and maybe its nothing to worry about ???
When you know the rate of leakage you can decide what to do about it.
Rapid loss (1 quart per week) ==> fix immediately.
Moderate loss (1 quart per month) ==> fix within 30 days, watch the level until then.
Slow loss (1 quart per year) ==> don't fix; replenish as required.
Originally posted by mitch33x
Do you have a slight leak from your tranny after adding synthetic? What brand did you use, Mobil, Redline? Is the shifting a lot smoother? Thanks...
litch
123
01-04-2024 07:01 PM
03-12-2020 12:06 AM
JoshG
51
09-21-2015 10:41 PM
