A/C Problems....
Old Aug 27, 2001 | 08:36 AM
Andre 3000's Avatar
No matter what button i press on the a/c controller, for like defrost, a/c, recycle, and the other buttons the air stays the same and always blows warm. Anybody know what i'm talking about or know the problem?
Old Aug 27, 2001 | 09:07 AM
njmaxseltd's Avatar
Sounds like you have a leak and lost all the freon. Have an A/C or radiator shop take a look at it.
Old Aug 27, 2001 | 10:20 AM
humaras's Avatar
auto controls?
Just wondering do you have the auto control or the manual controls?
for mine--when the days are not too warm or cold, the unit does blow out warm air but otherwise it works very well.
Old Aug 27, 2001 | 11:13 AM
KiLIAkLoWn's Avatar
Info..
Sounds like a compressor. I had a lincoln that blew hot air and they had to change the compressor and the cluch fan.
Old Aug 27, 2001 | 01:18 PM
Kevlo911's Avatar
Kevlo for President
if u have the warenty go get it fixed for free
Old Aug 27, 2001 | 02:23 PM
Neptune97's Avatar
AC
There are a bunch of things this could be...
Turn the car on, turn the A/C off (or atleast put it on econ mode), role down the windows, and then hit the A/C button.
If you hear the compressor engage, and you can see a drop in the RPM (and then a rebound) then you atleast know its not the belt or compressor clutch. If this doesn't happen, then that's most likely the problem...either that or something as simple as a blown fuse (or something else in the electrical system).
If the compressor does engage, yet warm air is still coming out of the vents, its most likely either the compressor, or something has gone wrong in the refrigeration loop (maybe the expansion valve or something is clogged elsewhere in the loop). As long as the engine does not overheat, you can pretty much be sure its nothing wrong with the radiator.
Can you change where the air comes out of the blower? (ie feet, face, defrost, etc)
Old Aug 27, 2001 | 09:40 PM
max808's Avatar
Freon?
I think our car uses 134A?
Old Aug 28, 2001 | 05:14 AM
Neptune97's Avatar
Re: Freon?
R-134A is a common refrigerant used in automobile A/C systems...I think you are correct.
Old Aug 28, 2001 | 05:31 AM
njmaxseltd's Avatar
Re: Freon?
R134a = Freon There are many types of Freon on the market. R12 -(which is not produced but IS available) R22, R134a -(soon to be discontinued also) R502, and the list goes on. They vary in pressure ratings and chilling capacity.
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
