Power steering boost adjustments?
Is there any relatively easy way to reduce the amount of boost running to the power steering unit? I already have a UDP but that didn't make much difference at all in the steering weight.
I suppose I could find a larger diameter pulley specific for the power steering unit (which would end up driving the pump slower).
The weighting feels pretty constant all the way around and it isn't softer in any one area compared to another.
I'd like to add a good 30-50% more weight into the wheel.
I run the tire pressures around 32PSI.
Any ideas? Are there any variables in power steering fluid types that could come into play?
Installing different pulleys will change the boost characteristics but you can't predict the magnitude of the change. The bypass valve provides infinite variability. You can change it from day to day, easily and without additional cost.
So I looked up the Power steering assembly in the service manual of the car. I see where they refer to flow control valves on some exploded assembly views. I suppose those are just simple restrictors but not totally sure.
Anybody know this for sure?
I was talking to a coworker of mine who used to be a mechanic for several years... suggested to experiment with inline restrictors. My coworker said it actually is a quite common modification that a decent shop that works on steering systems could do -- parts are supposedly fairly cheap too.
lowpost99
Oct 26, 2025 06:53 PM
