How much difference in acceleleration do larger wheels make?
Old Sep 11, 2001 | 08:50 AM
NmexMAX's Avatar
dot dot dot ...
I was wondering about this lately because ever since I have had my 17's on, I have been losing races that I have won before I put my rims on.
I know this subject has been covered before, but the search function didn't yeild any valid results.
Old Sep 11, 2001 | 09:03 AM
maxima42's Avatar
By putting aftermarket wheels on your car, it makes it significantly heavier. The factory wheels are going to be much lighter than 17's. The engine now has to drive larger wheels that qweigh more, which is why ou noticed a difference in your acceleration.
Old Sep 11, 2001 | 10:51 AM
hokiemax's Avatar
It makes a lot of difference I guess.
I had 15" GXE hubcaps for a week, as opposed to my stock 16" SE rims. The car was a lot faster, at least it seemed like it. I'd be driving around without thinking about the 15" hubcaps. I'd be like "man, the car feels fast today!"
and a minute later "OH that's right, I've got the hubcaps right now."
Old Sep 11, 2001 | 11:52 AM
operationNOS's Avatar
just my thoughts....
so why doesn't everybody just run with hubcaps.. instead of going all out for rims... is it just for looks, how many benefits are there in rims?
-Aaron
Old Sep 11, 2001 | 11:57 AM
190hpKiLLA's Avatar
Granny Driven
Re: just my thoughts....
-Aaron
Its All about the style!!!!
Old Sep 11, 2001 | 12:07 PM
maxima42's Avatar
true rims add a lot of style, but if you plan on racing you are better off going with either factory stel wheels with hubcaps, or with lightweight racing wheels.
Old Sep 11, 2001 | 05:37 PM
MAXEJA's Avatar
i have 18's on my car and you can tell a huge diff. in acceleration, also when applying the brakes. It takes more time to slow my car down. But it is worth it for the looks.
Old Sep 11, 2001 | 06:24 PM
Vyrus's Avatar
RE: Larger Wheels...
I have Racing Hart CP-035s in a 17" size, and they weigh in at 13.7 pounds (although they're supposed to be 13.5 lbs.). They are considerably lighter that stock wheels, however I do not really see an acceleration gain. But here is what I see of the Racing Harts as opposed to my 1996 GXE steel wheels.
  • +More road feel (more bumps; stock is too cushy)
  • -More tire spin
  • -People staring at your car and checking it out
  • -Worse looks because they look aweful without lowering springs (which I now have).
I see 3 - and 1 +, so I think maybe I should have stuck with the stock ones. I could have done so much more with the money......and the tire spin might be a result of my Yokohama tires, but I still think it's because of the wheel weight.
Old Sep 12, 2001 | 09:38 AM
sleeperGXE's Avatar
Re: RE: Larger Wheels...
Anybody know how much stock 15" GXE steel wheels weigh?
Old Sep 12, 2001 | 11:09 AM
abnorm's Avatar
Re: Re: RE: Larger Wheels...
Who here thinks that stock wheels look better without hubcaps?
Old Sep 13, 2001 | 05:29 AM
BEJAY1's Avatar
Conecarver
Just G-teched my 17" vs 16" OEM wheels. I know the launch and conditions really make a difference but my 0-60 looks like .10 - .15 sec improvement with the smaller rims.
Unfortunately the 1/4 suffers with 16" as I'm near redline before the 1320' mark in 3rd. Guess I gotta insert another shift in there...
Old Sep 13, 2001 | 05:57 AM
Frezny's Avatar
not necessarily
It's not the exact weight of the wheel. It's the placement of more inertial mass at a larger distance from the center of rotation. It exponentially increases the inertia of rest when you have larger diameter wheels. You can get plenty of 17" wheels that weight less than half the stock wheels, but the intertia will hurt you the heavier the wheel.
That's a significant difference in acceleration wich obviously shows more in the 0-60 times because of inertia of rest when the car is not moving is exponentially greater with larger wheels. However, your 1/4 isn't "suffering" as much as the fact that you have accelerated quicker, and thus reached redline quicker. This is a good thing. But your car slows accelerates a little less near readline (6200 rpms) than it did at about 5,200 rpms, and it feals like you're "suffering".
Old Sep 13, 2001 | 09:26 AM
NmexMAX's Avatar
dot dot dot ...
Larger diameter wheels are supposed to help cornering as well as looks, at least that's what I thought. So how much is .1-.15sec difference in terms of length, you know, is .1 equal to about a half carlength or so?
Old Sep 13, 2001 | 10:23 AM
TurDz's Avatar
I think 16'' wheels are the best compromise of size. They provide very decent handling, and you don't lose too much on your trap speed.
Vyrus, you should be spinning your tires at all...I have 16'' and I don't. It probably is your tires. For your next tire, get Potenza RE730 or 950, a little noisier in the cabin, but NO MORE tire spin.
anyway, hope that helped.
Old Sep 13, 2001 | 11:20 AM
SuDZ's Avatar
Re: Re: just my thoughts....
For some thats all it is about.
SuDZ
Old Sep 13, 2001 | 07:07 PM
BEJAY1's Avatar
Conecarver
I don't streetrace but I can guess. Ok math...
Say 95mph trap speed = 528,000'/hr = 146.66'/sec = 14.66' in .1sec.
How bout 14.6' - 22' length for a 1/4 or streetrace to 100mph. .1sec means over a car length.
Am I close?
Old Sep 14, 2001 | 12:38 AM
black019's Avatar
*** gettin 18's yo im gettin 13 inch enkeis
Old Sep 14, 2001 | 01:51 AM
Nismo's Avatar
what about putting 2 doughnuts in the front
Old Sep 14, 2001 | 10:07 AM
ptatohed's Avatar
Licensed to Spell
This topic is interesting...
When I first decided which size wheels to purchase, my only considerations were:
larger wheels = better looks, better handling
smaller wheels = better ride quality, cheaper price
I never considered smaller = faster. I learned about that after I made my purchase. I'm still very curius as to the speed differences though. BEJAY1 was nice enough to do a G-Tech run for us and came up with 0.1s for 0-60. But that was from 17" to 16" alloys, what about 17" to 15" steels? Or 18" to 15"?
Also, how would changing the actual outside diameter of the tire (not just the rim size) affect acceleration/speed? I know the odometer will be tweeked but would going either larger or smaller make a difference? Nismo joked about it but seriously, would racing with two spares on the front help a lot? Less traction certainly but mega light and smaller total outside diameter.
Also, I was thinking about the concept of bigger sidewall absorbing more energy. Kinda like when you have shocks on your mountain bike, you expend more energy because the shocks sap your engergy. Or how soft skateboard wheels will roll slower than hard ones. So why can't that concept be applied to cars?
And what about cars that are lightening fast that come with 17/18/19 inch rims like the M3, Corvette, Porsche, etc.? Would those cars be even quicker than they already are if they had 15's?
All I know is when I went from my 15"s to my 17"s, I noticed the BIGGEST improvement in handling. I love it. It's just too much fun taking those highway onramps at speeds that smush you into your car door without any tire squel. It's a little work but I feel the best compromise is getting the 17s/18s you want and keep your 15's handy for those Friday nights. :)
Old Sep 14, 2001 | 10:23 AM
dwapenyi's Avatar
Re: This topic is interesting...
If you change sizes that affect your overal diameter, you are actually changing the gearing of your car.
Generally speaking, putting donuts on your front wheels will make your car very fast. Well, assumming you can get good grip. Maybe 13 inch wheels with 215 tread would be better. 0-60 times will probably be better than any Max out there. Handling will absolutely suck, though The large sidewall will have too much flex, making handling mushy. And, your top speed will be much lower. It'll get to the top speed faster, but the top will be lower. If going straight the fastest is what you want, getting wide
13" wheels and tires would do it.
If you put on wheels and tires that make your effective diameter larger than stock, your car will accelerate slower, but your top speed can be higher. I say can because the gearing may be too much for the car's given power to overcome. As it is now, a stock Maxima can not get to red-line in 5th gear. When you reach your top speed of 137-140 mph, your car is at 5800 or so rpm. That's about 800 rpm below redline. The car just can't push anymore. Aerodynamic forces have become too much. Well, not too too much, you're doing 138 mph Not bad for a ~200 hp V-6, not bad at all.
DW
Old Sep 14, 2001 | 10:38 AM
NmexMAX's Avatar
dot dot dot ...
I was thinking of getin 215/55 15's, or 205/60's up front! yeaa. for those friday nites, ha!! that's tonite!! I'll do this and race the same guys i lost to and tell you guys what's up! peace! I'm goin to lunch!
MatthewsMaxima
Sep 11, 2015 03:21 AM
02nissmax
Sep 5, 2015 01:50 PM
MichMaxFan
Garage and Workshop
Sep 2, 2015 06:35 AM
cstrasz
Aug 27, 2015 08:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
