Lighting Issues
Old Sep 11, 2001 | 07:04 PM
operationNOS's Avatar
Ok, I put in the nice little hyperwhite bulbs on the front... and on the cornering bulbs... but I noticed that damn film nissan puts inside the cornering lenses make them a nasty yellowis color. Is there anything I can do to fix this discoloration... any help would be greatly appreciated.
Old Sep 11, 2001 | 07:51 PM
Ravq's Avatar
I don't have this film on my corner lenses. Are you sure it's a film or could it possibly be just dirty. You could replace them with the 97-99 corners. They are quite a bit clearer than the 95-96 just like the headlight assemblies.
Old Sep 11, 2001 | 08:07 PM
I actually forgot to post the meat of my problem, I need to know how to get the corner lens out. I found one screw and one little clip, but the bottom right corner still won't come out. Any help with this issue would also be greatly appreciated.
Old Sep 11, 2001 | 08:30 PM
seven's Avatar
you can take out the bulb without removing the lense
you have to use both hands and fit them into that little corner, but its better than breaking the lense by yanking too hard.
Old Sep 11, 2001 | 08:49 PM
Re: you can take out the bulb without removing the lense
The problem is not with the bulb, I've already replaced the bulb. The bulbs are hyperwhite, but the lens is making it appear more dull white.. which is bad, so I need to get out the lens itself.
Old Sep 11, 2001 | 09:01 PM
thebigsadler's Avatar
Re: Re: you can take out the bulb without removing the lense
okay.. there is a yellow film inside of the lense on the 95-99 corners.. no matter the 95-96 or the 97-99.. i know because i have tried em both.. "hyperwhite bulbs" are only truly hyperwhite when they are on there 27W filament..
all you need to do to get the hyperwhite brightness you want from them is the corner "rewire." But you can do it very easily.. all you do is rip off the higher of the two little nubs on the side of the bulb stem, and place the bulb in the socket backwards.. the little nub slides in and presses down and twists
to get the corner lense off there is a clip behind it that is tricky to get out.. i gave up after 15 minutes of prying and broke the clip off.. the screw up top holds my corner in and has for a year and a half.. it will work fine..
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Jan 20, 2018 05:05 AM
AnsonJ
Jun 2, 2017 01:35 PM
doctorpullit
Aug 20, 2015 05:15 PM
