Drag with Honda
This is off the topic but the general forum is closed.
Okay, this guy comes up and is by himself in a Honda Ra***a. If you don't know what this is, its a family sports car with a north south 2.5 5 cylinder but is front wheel drive. Weird??! Anyway, this one was a manual so I thought it would be a hard challange since I have an Auto 95 with the 2.5 VQ. So we drag off and he stays even till 80km where I pull slowly. (ps I had 2 other people). next drag the same except this time I load the trans up, but it still bogs terribly. third time I do a neural drop from rev limiter which is the only way to stop bog, and by the time he hits 60, we're neck and neck, but I gain while he changes to 2nd. his shifts were perfect, but there was enough for me to gain. Anyway later on we weigh the cars (there is a weigh bridge at a factory near the town that is left on sometimes, I come in at 1390 kg with fulltank, no people, 1650 with three people. The Honda was 1350 (car) and 1430 with driver.
Originally posted by 1/3There2/3ToGo
Yes...please elaborate on how you did your neutral drop at the limiter and didnt blow your tranny.
Kirk
Kirk
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
Originally posted by NZ Max
hmmm. I knew it was bad but didn't think it was THAT bad. Id look quite a fool at the lights with broken tranny under me...
Kirk
Its all good, just dont do that anymore...When I go to the streets or strip to drag I torque brake it. I push hard on the brake pedal with my left foot and rev the engine up to 2000-2500 depending on how smooth the surface is where I will launch from. Tires will spin a little, but then grab and you shouldnt have any bog.
Kirk
Kirk
Kirk
Kirk
my 1st car was a Mitsi Sigma 1.8 diesel turbo auto.
I used to do that all the time to get the turbo going so I could keep up with the likes of geo metros and anything under .8 litre. i ended up having only 1,2,3, no OD, No Rev, Park was 1st gear, Neutral was 1st gear.... buggered
Isnt loading the tranny bad too?
Kirk
Hmmm...havent heard a single bad thing about it yet...what were you loading it up to rpm wise?
Kirk
Kirk
(the .1 is probably what it did, it was that crap, but hey, 1st cars are always the ones you have the most fun in i think)
till the turbo kicked in with its .1 pound of boost at 2200
Kirk
The trans is not meant to be abused like that. I did it a total of about 7 times in a week and on a saturday the final time I did it I lost OD,3,and 2nd I drove home in 1st very sad.You are putting some much strain on the trans by doing this.An auto isnt built to handle that many RPM at once.
Then I scrapped that car, got a mitsi tredia, burnt the clutch in that (4 speed supershift), got a toyota cressida, didnt like that, traded the cressida and tredia which was still drivable in on my 1st max, 89 se auto. then it blew heater core which stuffed ecu, so fixed then tradedit on mitsi magna 3.0 v6 5 sd. traded that on toyota corolla, 3 wks later hated the corolla so got the 4th gen. And Im only 18.
Yes, thats what I did, except i did it about 30 or 40 times, the guy said it was like riding the clutch in a manual box and it had worn down that one of the many clutches in it had welded itself together causing the 1st gear in P,R,N and no OD.
Got rid of the 2nd gen cuz the are very few mods for them.
Kirk
Damn yo, Im on my second car, first was an '85 2nd gen maxima SE 5-speed, and im 19.
Kirk
Kirk
I will buy them if you want to sell.
Well actually, I only need the M A X M A as i already have an I from the CEFIRO. but theyre probably different lettering anyway. what do you think?
what did you do with your maxima letters?
Kirk
I'd sell them but both M's and both A's got bent when i took them off...sorry...and the I is somewhere at the dump since i didnt think having one letter would do any good.
Kirk
Kirk
Thanks anyway.
Thanks anyway.
Kirk
