power antenna question........
Old Sep 20, 2001 | 02:17 PM
redlantrn's Avatar
Is there any way I can keep my power antenna up on my Max? I want to hang a flag from my antenna, but not have it go down. Its a 99', and I have not been able to locate a fuse solely for the antenna. I also do not want to do anything too extensive to accomplish this if able to.
Thanks,
~J
Old Sep 20, 2001 | 02:45 PM
mbhang's Avatar
Re: power antenna question........
Thanks,
~J
Here are the steps
1) Switch on the radio
2) Open trunk
2) Remove the Grey shroud on the inside right .
3) Remove the power antenna power supply
There you are.
Manish
Old Sep 22, 2001 | 07:46 AM
redlantrn's Avatar
Re: Re: power antenna question........
Umm..I did as you said, and found a grey wire that plugs into a
metal box on the trunk interior right near antenna motor. I unplugged it and the antenna still goes down when I turn the radio off. This is the only wire visible, aside from some tail light wires that plug into it also.Any other info?
thanks,
~J
Old Sep 22, 2001 | 08:15 AM
mbhang's Avatar
Re: Re: Re: power antenna question........
thanks,
~J
I think the grey wire is the antenna wire (now, was there a marked deterioration in radio reception after you removed the grey wire).
You should try to find the connector that goes into the antenna motor and remove that one.
Let me know if you can do that.
Manish
Old Sep 22, 2001 | 08:35 AM
Daniel B. Martin's Avatar
thanks,
~J
Does your car have the Remote Entry feature? If so, the Multi-remove Control Unit (LCU05) is located near the antenna motor. Perhaps you disconnected that unit rather than the antenna motor.
Old Sep 22, 2001 | 08:44 AM
thebigsadler's Avatar
Re: Re: Re: Re: power antenna question........
the two plugs you removed were for the remote entry system.. I tried this the other day and realized that when I read the metal box's label.. haha, I couldn't see the antenna motor, I am guessing it is right next to the jack, BEHIND that metal box.. but I couldnt find it..
Old Sep 23, 2001 | 07:27 AM
redlantrn's Avatar
Re: Re: Re: Re: Re: power antenna question........
Yes, I do have the remote entry system. I tried unplugging both wires from the metal box just to see what happens. I even tried taking out the jack, and jack mounting bracket to see if I could get a better view behind the panel to no avail. Was only able to locate signal reception cable, but no power lead. I was hoping it would be a simple fuse pull. Thank you all for your input.
~J
Old Sep 23, 2001 | 09:36 AM
Re: Re: Re: Re: Re: Re: power antenna question........
~J
The "power lead" is part of a wiring harness. You want to locate (by sight or feel) a white plastic 6-pin electric connector and disconnect it. It may be necessary to remove the entire power antenna assembly to do this. I don't know for sure because Plain Jane (my '99 GXE 5-speed) has a fixed mast antenna, not an up-and-down power unit.
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
