Weird chirping noise coming from engine bay
Re: Re: Weird chirping noise coming from engine bay
Originally posted by ereet
Wierd chirping noises from the engine bay eh? Bring your car over to my place and lemme borrow it for a few days .. I'll have it removed for you
I have a simliar sound. It occurs at about 2,800 rpm and goes away shortly there after, unless I'm winding it out. Daniel B. told me to check the EGR system. I've checked all of my belts, changed everything I possibly could. this weekend I will be checking my EGR system.
Originally posted by bosco500
I am getting a chirping noise coming from my engine bay.. kinda sounds like crickets.. anyone know what this could be?
mike
Originally posted by emax95
I think the cause of the noise is the barring in your supercharger, I remember my I30 made that same noise .
Originally posted by Infiniti
i get this whistling noise when i'm driving 70-75 mph. when i release the pedal and let it fall under 70 the noise is gone, and when i step on the pedal to pass 75 the noise is gone. you know what's causing this?? this is on an I-30.
Originally posted by medicsonic
Infiniti, I'm going to put this nicely for you. Your I30 IS a Maxima. There are VERY FEW differences between the two. VERY few. So you don't have to point out in every post that you have an I30. What holds true for a Maxima holds true for an I30.
so wats causing the noise?
if you think it's engine noise, does it happen at 70-75 in 4th and 5th gear?
mike
Originally posted by 98maxse5spd
could it be wind noise? maybe one of your windows/sunroof isn't sealing right?
mike
mike
it does happen in 4th and 5th gear. i can play a tune just by stepping and releasing the gas pedal. how bad is that?
hey mike,
hey mike,
never troubleshot the former, but if i had to, i'd start taping off cracks and creavices like the sunroof, headlights, body lines, etc.
i couldn't make an educated guess on the latter. maybe get a buddy to crawl around the car while its happening and see if you can isolate it. my guess is that it's wind related anyway.
do you have any aftermarket bodywork that might be causing it?
mike
i had a chirp/squeak noise when i shut off my engine too, after using the A/C usually. mechanic at the dealer said it was just remnant air passing thru one of the valves while it was in the middle of a test...have a chirp noise coming from plenum when i rev the engine in drive or park with all the lights on...
Viralkill
08-17-2015 10:54 AM
Nintensity
08-13-2015 05:41 PM
