Special tools for installing lowering springs???
Old Oct 2, 2001 | 11:21 AM
97GreenMax's Avatar
I am looking at getting some lowering springs this week or next week. I have asked a few shops how much they charge to install them, and they all said 4-5 hrs @ approx. $50 an hour. So my question was, can this be done at home, would I need any special tools to do it?? Thanks.
Old Oct 2, 2001 | 11:23 AM
mzmtg's Avatar
Minister of Silly Walks
SEARCH!
Yes you can do it on your own. It should take about 3hours. The only odd tools you will need will be a spring compressor and a torque wrench. Both ofthese can be loaned to you by Autozone for free.
Peoplw will tell you that no spring compressor is needed, but it's the safe thing to do.
Old Oct 2, 2001 | 11:25 AM
Jeff92se's Avatar
I'm needing a caw
No special tools but you MUST rent a set of spring compressors.
You should have a decent set of basic hand tools in order to do this job right. Plus a 1" drive breaker bar that's about 4-5 long and a very large 1" drive socket for the cv joint nut.
4-5 hours to do struts/springs is rookie time. Any shop worth their noodles should be able to do this in about 2 hours.
Old Oct 2, 2001 | 11:30 AM
mzmtg's Avatar
What choo talkin bout CV joint nut??
You dont have to mess with that thing when just doing springs and struts. Unless you are referrring to the two big bolts that hold the strut and hub carrier together...those are 17mm bolts with 19mm nuts.
Old Oct 2, 2001 | 12:00 PM
njmaxseltd's Avatar
Tools needed. Spring compressor to remove the stock springs. 17mm box end wrench, 19mm 1/2" drive socket with breaker bar to get the bolts lose on the lower strut mount. 10mm socket for ABS lead if you have abs. Screw driver to knock out brake clip, 21mm socket for upper strut mount nuts. 17mm deep socket if I remember correctly for the strut shock bolt and of course a friend, a jack, jack stands, torque wrench, and a NEW set of strut bearings. It's totally worth it to replace these for 40 bucks now, rather then take the whole Frigging thing apart again later on. Air impact socket driver makes the bolts come out really easy. But don't put them back on with it!!!!
Old Oct 2, 2001 | 10:49 PM
syc's Avatar
syc
Anyone know how much are the spring compressors? I'm considering buying it with my friends together if the price is not bad.
Old Oct 2, 2001 | 10:55 PM
emax02's Avatar
About $50.
Old Oct 3, 2001 | 11:57 AM
syc's Avatar
syc
Originally posted by emax95
About $50.
Not bad! thanks
Old Oct 3, 2001 | 01:20 PM
VQdriver's Avatar
Re: Special tools for installing lowering springs???
make sure you have detailed diagrams as to how to remove them using the tools! have a lot of patience/time if it's your first time doing it. be prepared for anything to go wrong. i made the mistake of thinking it was too easy and now i'm paying for it. oh, and don't install your springs upside down!
dank4us
34
Jun 10, 2024 03:45 AM
homeyclaus
Sep 3, 2015 06:15 PM
95Maxi
35
Sep 2, 2015 10:37 AM
twotonezed
Aug 16, 2015 08:10 PM
twotonezed
Aug 16, 2015 11:41 AM
