What RIMS!!! look good on a 98 maxima??? Should i get 18 or 17 inch
I am looking at the verdicts.. but im not sure. 17" rims or 18" Help, im overwhelmed!
Post pics of your cars if you could,
Thanks,
Destined to configure the perfectmax!
Thanks,
re: rims
I plan to get 18" chrome rims myself in spring 2002...right now i got
hub caps. 17"-18" is like adding couple of people to your car and u'll have same weight.
go for the looks as well as performance...you can do both which is the best in my opion, u gott have the looks as well as performance.
pz
pz
Re: What RIMS!!! look good on a 98 maxima??? Should i get 18 or 17 inch
Thanks,
Thanks,
I have verdicts in 18. Get 19's. Or you'll be ****ed everytime you see someone else with them. At least if you got the big dogs yours are the best! Na thats bad logic.
Get what you can afford. But not verdicts cause I have em. Kiddin.
Originally posted by njmaxseltd
17's perfect blend of performance and looks without the ride sacrafice.
Re: Re: What RIMS!!! look good on a 98 maxima??? Should i get 18 or 17 inch
Originally posted by Stillen_I30
Get 18's. After I got my 17's, all the latest models are coming standard with 17s (I30s, Maximas, Altimas come with them as an optoin, etc.). So now I want 18s...i think anything larger looks too overstated.
Re: re: rims
pz [/B]
pz [/B]
Bingo, thats the way to go. light azz 18 in rims. go fast and look good at the same time
oh.. one more thing.. dont be swayed by people telling you that your ride will suffer on 18's compared to 17's. its all in the tire size. dont get something too low-profile. put it this way.. i have a 95 gle, my friend has a 96 gle. my friend has stock struts, springs, and 17" chromies with low pro's. i have h&r springs, kyb struts, rsb, 18" eneiki(spelling) v1's with a nice size tire. my car handles better, and has a more comfortable ride than his. ive been in both cars plenty of times so i know, plus we live in nyc, so there's the real test. i saw no difference in my ride from when i had 16's to when i threw the 18's on other than turning cause these are wider. not to mention, he's blown out 3 tires already and bent all 4 rims slighty. (steel rims).. your tires are going to affect your ride the most. dont buy anything too low profile, and get a soft tire.. my tires are 245/40/r18 toyo's. i would HIGHLY recomend them and i wouldnt recomend buying a set of very light 18" rims either. one bad pothole and you'll be doing this
to try and straighten them out.. kiss that money goodbye
Originally posted by KCTYPHOON
i would HIGHLY recomend them and i wouldnt recomend buying a set of light 18" rims either. one bad pothole and you'll be doing this
Originally posted by matt calder
Uhhh, that is not entirely true. If you buy lightweight wheels, they are going to be expensive, The higher priced rims hold up better than the lower priced rims. My rims are stronger that the Konig copies of mine. Its that simple.
I saw this thread and I wanted to ask a couple of questions. How do you find the offset of wheels? Is there a website I could go to? I plan on upgrading brakes also. Any suggestions? Should I do a whole brake kit or piece it together?
K
K
Check out www.tirerack.com they have a large selection of rims, plus you can see what they look lke on your car. My $0.02.
YourLocalAsian
Aug 17, 2015 02:33 PM
criminalslang810
Aug 16, 2015 08:12 AM
