stalling 95 gle update - thank you guys!
just a quick "thank you" to emax95, medicsonic, suzd & daniel b martin & nismo98! i just installed the new (well, remanufactured) mafs and my max is back on track! i couldn't have done it without your help. with your advice i was able to save myself money, down time at the garage & now i have the haynes manual & multimeter for future use. you guys are great.
let the record show that with my stalling/ bucking syptoms, a new mafs was the answer. also, i paid $199 at my local "national auto", which is a good price, i think.
thanks
maury
thanks
maury
Re: stalling 95 gle update - thank you guys!
thanks
maury
thanks
maury
- saves money
- learns more about how his car works
- takes pride in his skill and self-reliance
thanks
maury
thanks
maury
. MAFS are a real pain in the but, they seem to be the #1 broken part these days.
stalling
hmm..my 95 max is stalling everytime i start it. I turn the key and nothing happens and then i gotta rev the gass to kepp it going. one friend told me its a starter, another told me it was that I need a tune up..any idea? also my engine light is on
Re: stalling
well, now that i took some good advice from friends here - i now have the trusty haynes manual. do you have one? if so, check out chapter 6 and get the trouble code from your car. in theory, that will tell you why the check engine light is on. in my case, it correctly told me my mafs was bad. also it warned me that my knock sensor was bad too - but lots of people here say that may be a programming error on missan's part. good luck.
maury
maury
Re: stalling
Read the Sticky
... also my engine light is on
Please read the Sticky Thread Important: ECU Diagnostic Trouble Codes . The first post in that thread contains a pointer to a Web site with detailed instructions for doing a DTC readout. No special tools are required. When you know the stored DTCs, you will have a fair idea of what repairs are needed.
Sorry, I missed the original thread - What is a "mafs"?
thanks
maury
thanks
maury
MAFS
For more information about the function of the MAFS and a test procedure, please refer to the Chilton repair manual (page 4-16) or the Haynes repair manual (page 6-9).
engine trouble
Sorry about my previous post, I'm not good at explaining things. But I did check out the engine codes...I got 3 slow 4 fast and that means "Knock sensor" I also got 1 slow 3 fast...which means "Engine coolant temp sensor". I Have no idea what these mean. i am a complete moron when it comes to cars. My problem is this, I attempt to start the car..and nothing happens..then I sit...wait. turn key..nothing, i hold turned key for 3 seconds, car starts starting...but will only run if i rev the engine, if i don't rev the engin after I start it, the car slowely turns off..RPM meter slowely goes down. other then the starting process, everything is fine. If anyone knows a way to help me, it would make me happy
Re: engine trouble
BTW Daniel B., a while back I posted a problem with my car not starting correctly and thanks to you I believe I pin pointed the problem. Like you said, it may be the Crankshaft Position sensor. I tested it out today and the sensor is dead. Thanks for your help!
Read the Sticky
Please read the Sticky Thread Important: ECU Diagnostic Trouble Codes. The post titled DTC 0103 in the Sticky provides instructions for testing the Engine Coolant Temperature Sensor. Please make this test or pay a qualified person to make it for you. There may be a defect in your ECTS or the associated connector and wiring. This kind of defect could cause the problems you report.
doobadoo
Aug 15, 2015 06:43 PM
