starter going going about to be gone...
Old Oct 4, 2001 | 09:26 AM
Justin95SE's Avatar
anybody replace their starter or know of a link ?
Old Oct 4, 2001 | 09:38 AM
clee130's Avatar
Replacing your starter is easy.
http://vbxmaxima.8m.com/starter.html
Just make sure you have a long breaker bar. In my 95, some of the bolts were really really tight.
Old Oct 4, 2001 | 09:45 AM
Daniel B. Martin's Avatar
Re: starter going going about to be gone...
Starter replacement is a job which can be done by the home mechanic.
No need to jack the car, the starter motor is accessed from above.
Remanufactured units are available for $140 (Brand X) up to $360 (Bosch).
If done by a professional the labor charge ought to be one hour.
Make written notes of the radio station presets. Disconnecting the battery will cause the radio and clock to experience "amnesia".
1. Disconnect the cable from the negative terminal of the battery.
2. Remove the air intake duct and the air cleaner housing assembly.
3. Disconnect the battery cable and the solenoid terminal connection from the starter solenoid.
4. Remove the two starter motor mounting bolts and remove the starter from the engine. These bolts may be really tight!
Installation of the starter is the reverse of steps 1-4, above.
The factory specification for starter mounting bolts is ...
short bolt 22-30 foot-pounds
long bolt 57-72 foot-pounds
Set the clock to the correct time. Refer to the notes made in step 1 to restore the radio station presets.
For more information (and photos) go to http://vbxmaxima.8m.com/starter.html
Old Oct 4, 2001 | 09:47 AM
asianmotorsports2000's Avatar
Just had mine replaced
Do to lack of time on my part... Had my mechanic do it... parts and labor was $315.00...
Old Oct 4, 2001 | 09:53 AM
clee130's Avatar
Dealer quoted me approximately $400 to replace my starter. So I just bought a starter from Nissan for ~$200 and did it myself.
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
