Brake rotor overheat & glazed problem
Old Oct 6, 2001 | 04:56 PM
Brockster's Avatar
After researching through the Maxima.org site, I come the conclusion that I grazed my front right brake rotor. Can someone tell me what this means and what I should do. I had already planned to purchase Axxis pads and Brembo or Porterfield rotor. I'll start a pad and rotor poll for user recommendations.
Brock
Old Oct 6, 2001 | 05:31 PM
iwannabmw's Avatar
If you put so much heat into the rotor and glazed them, you have two options. Either turn them (not reccomended because they will warp easier and dissipitate heat less) or replace them. Contrary to popular belief, you do not need cross drilled or slotted rotors in order to see a significant performance increase, though they do look cool. A good set of pads (Porterfield, EBC, etc...) will improve your braking tremendously, and fade a ton less than stock. The only reason you would need slotted or cross drilled rotors would be for looks or really exreme situations like driving on a track. My .02
Old Oct 6, 2001 | 09:30 PM
SLC I30t's Avatar
So what your trying to tell me is that all I need is better pads... how does a better pad disipate heat quicker than a cross drilled or slotted? How does a better pad allow the rotor to cool quicker than an upgraded rotor? Doesn't fade happen when the rotor over heat? I agree that a better pad would make an improvement. But when you are braking from 75-80(or 120) they do get hot... quick. I guess significant increase is left to your perception of the word?
Old Oct 7, 2001 | 01:41 AM
Chunger's Avatar
My other car is a Hybrid
Fade mostly is caused by the pad material not being able to handle the extreme heat. The rotors can virtually glow red and not be destroyed if cooled back down properly...
Old Oct 7, 2001 | 04:21 AM
SLC I30t's Avatar
So.....a rotor that stay's cooler...is a happier rotor....again, tell me why I don't want crossdrilled rotors?
Old Oct 7, 2001 | 05:57 AM
iwannabmw's Avatar
Like Chunger said, a better pad will accept more heat from the rotor and dissipitate it better up to a much higher temp. than "normal" pads. This is the more economical way to improve brake performance. I won't argue that going to a slotted or cross drilled rotor will increase braking/cooling even more, I'd lose. My point is that upgraded pads are more than up to the task for street driving and even some track driving. When I drive my car at Limerock Raceway, I hit 110 on the front straight and go down to 60 for the first turn combo. I use stock rotors and Porterfield R4S pads. My brakes won't even start to fade until about 20 minutes of repeatedly doing this. The stock rotors are up to the job. I can't imagine were anyone would "need" more cooling capacity than that on the street. Another example, is NHIS, which is a mucher harder braking track. The back straight I hit 95 and go down to 35, a much harder job for the brakes to do repeatedly without fading. There, they do fade earlier, but will still last a 30 minute session.
Like I said before, if you love the look of slotted or cross drilled rotors, by all means, get them. Just understand that. performance wise, they're most likely overkill unless you do a lot of track sessions.
Sorry for the long post.
Mark
Old Oct 7, 2001 | 06:28 AM
Brockster's Avatar
So, I'll place the order for the new rotors & pads and have them put on this week. I guess I'll just deal with the smell for a few more days. Since I'm supplying the parts, I imagine that my mechanic will charge me for about two hours labor. For my FYI, I still need a description for the term GLAZE. Should I buy a shim package?
I'm still trying to figure out how to post a poll thread. Keep your eyes open for one for brake rotors and one for pads.
Brock
Old Oct 7, 2001 | 09:56 AM
Chunger's Avatar
Crossdrilling is mostly for lightening the rotor for speed... Increase of surface area is minimal...
Think of it this way... Which takes longer to heat up? 15lb of metal or 10lbs of metal given the same amount of heat?
Old Oct 7, 2001 | 10:46 AM
Daniel B. Martin's Avatar
Originally posted by Brockster
... I still need a description for the term GLAZE. ...
A glazed rotor is one which has developed an extremely smooth, almost mirror-like surface. A glazed rotor does not have good friction characteristics.
Old Oct 7, 2001 | 11:04 AM
Brockster's Avatar
And the rotor Glazed just because of the overheating? Is this typical?
Brock
Old Oct 7, 2001 | 11:50 AM
Brock
Glazing is not typical but it does happen. I think your rotor would have to get really hot to become glazed. I've owned several cars of several different makes which were equipped with disk brakes and have never had a glazed rotor.
Old Oct 7, 2001 | 03:00 PM
SLC I30t's Avatar
iwannabmw-thanks for the post, I understand the physics better now.
So I'll ask you all as a groups since we have all the minds together... which brand of brake pad is the best? Do I need a different brake pad for stock rotor vs. slotted vs. X-drilled?
Brockster-Phoung is having a sale on his x-drilled rotors from stillen. I know they are cheaper than stock (so I was quoted 98 a piece from Tischer Nissan on Friday--phoung has them 165 a set).
Old Oct 7, 2001 | 08:28 PM
Brockster's Avatar
As a matter of fact, I spoke to Phong this morning. He pointed out that for normal street running, the Brembo JBR-505 blank rotors ($94/ front pair) would be my best chose. If I wanted to pay extra just for pretty looks, go with his Stillen drilled ($165/front pair) which are Brembo blank drilled by Stillen. I'm still trying to find some slotter rotors. I'd get them with the rust resistant coating. The pads I'm looking at are the Axxis Metalmanager ($47./front pair).
Hey SLC I30t, is that you with the white I30t at the DC meet a few weeks ago?
Brock
Old Oct 8, 2001 | 05:22 AM
SLC I30t's Avatar
Yes sir it was. Was that you with the rusty Addco?
Old Oct 8, 2001 | 07:10 AM
got rice?'s Avatar
As a matter of fact, I spoke to Phong this morning. He pointed out that for normal street running, the Brembo JBR-505 blank rotors ($94/ front pair) would be my best chose. If I wanted to pay extra just for pretty looks, go with his Stillen drilled ($165/front pair) which are Brembo blank drilled by Stillen. I'm still trying to find some slotter rotors. I'd get them with the rust resistant coating. The pads I'm looking at are the Axxis Metalmanager ($94./front pair).
Hey SLC I30t is that you with the white I30t at the DC meet a few weeks ago?
Brock
Brock,
If you're looking for slotted, the STillen are available in cross drilled *or* slotted
The Axxis Metal Masters are $47 for the front, not $94
Old Oct 8, 2001 | 07:44 AM
iwannabmw's Avatar
Other options for slotted might be EBC Turbogroove or ATE Powerdisc. Not sure if they make them for the Max though. You can check out www.brakeco.com
There's an 800# you can call to find out.
Old Oct 8, 2001 | 08:14 PM
Brockster's Avatar
Originally posted by got rice?
Brock,
Sorry Phong, I've corrected the price. Do you sell both the cross drilled and slotted rotors?
Hey SLC I30t, I had that rusty RSB returned for a better one. Unfortunately, I dealing with this brake problem right now. Steve said we would get together later to install both his and my RSB's.
Brock
Old Oct 9, 2001 | 05:44 AM
got rice?'s Avatar
Brock
The Stillen are one or the other, not both drilled * and * slottled.
Old Oct 9, 2001 | 06:00 AM
j_bryan's Avatar
Brock
What is the benefit of the Brembo JBR-505 blanks over stock rotors??
Old Oct 9, 2001 | 07:47 AM
Viscous's Avatar
Stillen Cross Drilled rotors and Axxis metal matrix pads work like a charm. Take you from 120 to 65 in about 2 seconds without fading! I know from experience because I almost drove past a cop on I-80 going 120, but luckily I saw him before he saw me and I braked really quickly.. He musta thought that it was impossible for someone to brake so fast =) hehe here is a picture of the x-drilled rotor attached.
Old Oct 9, 2001 | 07:51 AM
SLC I30t's Avatar
I'm sold on the x-rilled and pads... But I'm thinking about wether or not to do the lines now or wait... and back brakes...
Old Oct 9, 2001 | 07:58 AM
Viscous's Avatar
The lines and the backs can wait until you have enough free floating cash. You will feel a big difference already with just the front rotors and pads. Much more grippy and gritty and makes a really cool low hum when you brake firmly.
Old Oct 9, 2001 | 08:00 AM
SLC I30t's Avatar
Hey phoung...
may I have to bill please....
Old Oct 9, 2001 | 09:34 AM
got rice?'s Avatar
Hey phoung...
You've got the $150 gift certificate for taking first in the GR Racing autocross, so the bill won't be as bad
Old Oct 9, 2001 | 11:25 AM
SLC I30t's Avatar
I'll email you seperately but I want the front and rear rotors and brake pads.. I'll do the rest when I have more loot.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
