Poorman's UDP- disable power steering
Old Oct 7, 2001 | 08:38 PM
ericdwong's Avatar
I had a wierd thought as I was workin on my car tonight. The UDP spins the alternator, AC compress and power steering pump slower right? Well if you dont have the AC compressor running, the magnetic clutch wont be engaged, so thats not really an issue. As for the alternator, I cant slow that one down cause I gotta juice my stereo. But the power steering, I wouldnt mind if it took some more arm muscle to move. And I'm sure it places a drain on the engine, even when going straight. I'm thinkin aboug disabling the power steering by loosing its belt. Thoughts?
Old Oct 7, 2001 | 09:07 PM
Eric L.'s Avatar
Personally, I don't think that disabling the power steering is worth the slight increase in horsepower. Think about it...how often do you need the 1 or 2 horsepower it might free up? Maybe 1% of the time.
I would not do it, but it's your decision.
Old Oct 7, 2001 | 09:17 PM
Dave B's Avatar
Not DAVEB the parts guy
I'd recommend against this. The power steering pump has it's own belt. By disconnecting the power steering pump, the remaining fluid doesn't get circulated and after a while your power steering pump seals will start leaking. This would be a very expensive fix. It should also be noted that most of the gain from the UDP comes from it's much lighter weight, not it's 20% underdrive.
Dave
Old Oct 7, 2001 | 10:41 PM
sx7r's Avatar
have you ever tried steering the max w/o power steering? i'd like to see you parallel park or bust a U w/o power steering - especially when you're barely moving..
Old Oct 7, 2001 | 10:53 PM
Sonic's Avatar
AMOC
Tires weigh less if there is no air in them. Run without any air.
Old Oct 7, 2001 | 10:54 PM
dmontzsta's Avatar
Ford Only.
take all the air out of your tires.Run on flats.
Old Oct 7, 2001 | 11:00 PM
Sonic's Avatar
I just said that.
Old Oct 7, 2001 | 11:08 PM
sx7r's Avatar
Originally posted by medicsonic
I just said that.
hahaha
Old Oct 7, 2001 | 11:20 PM
Sprint's Avatar
i drive my moms sentra E.. that thing has NO power steering
Old Oct 7, 2001 | 11:26 PM
sx7r's Avatar
i drove my friend's civic and he took the power steering belt off. if the car isn't moving, it's quite a workout to turn the wheel. it only gets worse with a heavier car.
Old Oct 7, 2001 | 11:50 PM
guido_sst's Avatar
Ever tried steering a massively boosted Plymouth Colt without power steering? Biceps the size of tree trunks I tell ya!
Old Oct 8, 2001 | 12:04 AM
Sonic's Avatar
I've driven a bicycle without power steering. Light a feather.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
