Jet fuel ????
Old Oct 10, 2001 | 09:19 PM
maxima168's Avatar
Jet fuel ????
im going to run the quater this weeken. and my car is stock and i want to put jet fuel in it. but i have heard that my cat wont handle it? anybody every tired it?
Old Oct 10, 2001 | 09:28 PM
BRIGBOY's Avatar
I needed a good laugh. Thanks.
What is jet fuel exactly?
j-95G's Avatar
i say go for it! it prob won't add enough power to be worth the $5 a gallon you'll have to pay, but if it does blow your cat off, replace it with a better flowing one, or a piece of 2.5" pipe. that can only yeild positive results.
Old Oct 10, 2001 | 09:44 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Jet fuel ????
you do know REAL jet fuel is just clean desil right? so i would say let the JET fuel go and try race octane booster.
Old Oct 10, 2001 | 09:46 PM
sx7r's Avatar
Re: Re: Jet fuel ????
think he just means aviation fuel. 110 octane.
Old Oct 10, 2001 | 10:02 PM
Nealoc187's Avatar
SLOW
WTF, jet fuel haha.
Old Oct 11, 2001 | 05:46 AM
njmaxseltd's Avatar
CAM 2 gas. It's available at select gas stations. There is one here in Waldwick, NJ that sells it. I believe it's about 5.99 or more a gallon. Don't know what the octane rating is. Usually you mix one gallon of that with a full tank of regular fuel. I don't think I'd run the car on that stuff straight. Remember the higher the octane rating, the SLOWER the burn. Hance to much octane = loss of power.
Old Oct 11, 2001 | 06:12 AM
mtrai760's Avatar
'Trynna' is not a word
Actually, jet fuel is more like dirty diesel... Your car probably wouldn't run at all on JP5 or JP8...
Old Oct 11, 2001 | 06:16 AM
Sprint's Avatar
poor the jet fuel all over your car and light it
Old Oct 11, 2001 | 07:17 AM
Alex97se's Avatar
Re: Jet fuel ????
For God's sake, everyone please listen to me. OCTANE has nothing to do with performance. OCTANE IS A RATING OF THE GASOLINE'S RESISTENCE TO DETONATION. Gas shouldn't combust, it should burn. If your car runs without knocking when you use regular unleaded, then that is what you should use.
Old Oct 11, 2001 | 07:24 AM
deezo's Avatar
Re: Jet fuel ????
You will destroy your engine. I used to work with aircraft and the fuel is like syrup. It's called jet-a and jet-b fuel, a form a diesel.
Old Oct 11, 2001 | 08:17 AM
T-One's Avatar
Jet fuel is NOT diesel. Most jet fuels is a mixture of kerosene.
Old Oct 11, 2001 | 08:18 AM
Sprint's Avatar
no it won't.. i say he try it
Old Oct 11, 2001 | 08:48 AM
Bags's Avatar
Re: Re: Re: Jet fuel ????
if it's not i have used it for diesel motors and there we fine. but again i was told is was a cleaner form od diesel and stuck it in a OLD vw rabbit diesel and it ran. along with some other applications. but you could be right. i was just trying to tell him NOT to use actual jet fuel also known as jp-5 jp-8 depending on where you are
Old Oct 11, 2001 | 09:36 AM
mtrai760's Avatar
Jet fuel 101
JP5, JP8, JetA JetB, are all Jet fuel ratings. JP8 has antifreeze additives, and works fine on most jet engines, but will blow out some in warm weather. Think of it like octane ratings. On the T58-GE-16 (a helicopter gas turbine engine) JP5 is used normally, and JP8 in cold weather. JP8 can be used in hot weather, but fuel control adjustments must be made, or you can blow out the compressor... Most actual Jets, ie F/A 18, F-16, use JP-8 though...
Old Oct 11, 2001 | 11:50 AM
Synki's Avatar
Unless you have a highly modified car, i wouldnt bother with higher octane gas.
Old Oct 11, 2001 | 12:04 PM
maxima168's Avatar
RE: my b
my b. when I was referring jet fuel I was talking about I was going to mix 93 octane with 105 octane to get alit boosts or should I just buy a bottle of that NOS octane booster instead from autozone?
Old Oct 11, 2001 | 12:28 PM
deezo's Avatar
Re: RE: my b
I have done it and I think its a waste. My car runs fine on 93.
Old Oct 11, 2001 | 12:31 PM
justmax's Avatar
Yeah, it turns out that Diesel is pretty much kerosene too, so you're kind of right...
jet fuel, diesel, kerosene... all the same basic stuff at different stages of refinement/additives.
Justin
Old Oct 11, 2001 | 12:41 PM
JdawgX's Avatar
Don't bother with higher octane ie. 101 unless you have HIGHER compresion than stock and are running NOS with much colder plugs. Just a waste of $$$ and it won't give you any benefits.
Justin
Old Oct 11, 2001 | 02:17 PM
dashingMax's Avatar
Just use NOS
Forget high octane stuff. Spend the $700 and get instant 70-100 horses.
Jet Fuel *jeeez*
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
bbsitum
Sep 6, 2019 07:31 PM
Forge277
Jun 13, 2016 09:26 PM
