SC CAI problem
Old Oct 15, 2001 | 04:03 PM
bosco500's Avatar
SC CAI problem
okay, I went out and bought all the pipes and a 6" k&n cone filter with a 3.5" opening to make a CAI (according to chestons directions) . The only problem is that the filter will NOT fit in the fender well. I pulled the tire and lining off, and the windsheild washer fluid resorvoir is in the way. There is no way the filter is going in there. What filter is everyone using, or are you just removing that resorvoir? thanks
Old Oct 15, 2001 | 04:11 PM
Jane97SE's Avatar
Used force to obtain Admin powers
They are removing the resevoir.
Old Oct 15, 2001 | 08:32 PM
Cumalot's Avatar
Yeah, what she said.
Old Oct 15, 2001 | 11:38 PM
OgreDave's Avatar
removing? mines tucked behind my battery!
i could swear it was relocated not removed ..
Old Oct 15, 2001 | 11:49 PM
Cumalot's Avatar
The coolant resevoir is relocated. The windshield resevoir has to removed to fit the custom cai filter.
Old Oct 16, 2001 | 03:59 AM
bosco500's Avatar
cool I was wondering how in the hell it was going to fit. Does
this not trigger the check eng. light?
Old Oct 16, 2001 | 05:52 AM
Confused's Avatar
Permanent Maxima.org Resident
Another possibility is to stick the pancake filter in the fender well and line it up with the existing hole across from the s/c. You will need to widen the hole a little but then you can have a pipe made to go up to the s/c. Only downfall is the filter is 3" id to the 3.5 blower.
Old Oct 16, 2001 | 09:18 AM
BriGuyMax's Avatar
how do you guys wash you windshields then???
Old Oct 16, 2001 | 01:49 PM
ZXdude's Avatar
remove resevoir...
guess that means that you guys don't have the cool windshield washer LEDs
Old Oct 16, 2001 | 03:17 PM
Phil02E46's Avatar
there are ways.. just takes time and plotting
Old Oct 16, 2001 | 07:24 PM
MardiGrasMax's Avatar
Screw that windshield water bottle, I wash my car too often so I never use it any ways.
I used 3.5" mandrel bent tubing and some marine exhaust hose with a big *** K&N that will be able to flow enough air for a 3.5L motor with 14psi of boost
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
