Hydrolock !!! wtf !!
Old Sep 18, 2007 | 08:51 AM
Abimax95's Avatar
Hey guys I hydrolock my engine ...yeah sucks big time .. my question is I'm doin a engine swap so do I take my engine with the tranny all together or do I take the engine by it self .. I need to do the swap fairly fast since fall is almost here in MA , plus I need my car any help will be greatly appreciated ..
thanks guys !!
Old Sep 18, 2007 | 01:24 PM
97maximaman's Avatar
Well assuming your keeping your tranny then it doesnt matter, but whatever is safest. Its probably easier to take it out separate, you'd to get that engine at a crazy angle to take it out in one piece.
Old Sep 18, 2007 | 01:42 PM
Abimax95's Avatar
engine
Thanks 95maximaman that's what I figure but I guess either way I'm screw , that will be my project this weekend .. thanks again..
Old Sep 18, 2007 | 02:43 PM
wirelessdude04's Avatar
more and more off this is happening lol
Old Sep 18, 2007 | 03:40 PM
bipolar's Avatar
hey
Does the intake have to be completely submerged to hydrolock??
Can it happen from just spraying it accidentally at the car wash...?
Old Sep 18, 2007 | 03:50 PM
MOHFpro90's Avatar
Yes.
No.
Think about it this way. Put a straw opening 1/3 of the way in water, suck through it, and see how much water gets all the way up. Point is, water is harder to suck up because it weighs more.
TO the OP: Man that sucks. What kind of CAI are you running?
Old Sep 18, 2007 | 03:53 PM
nismology's Avatar
Water entering the engine doesn't necessarily mean it has hydrolocked. How have you confirmed this?
Old Sep 18, 2007 | 06:13 PM
96blkonblkse's Avatar
Yeah im curious to see if it actually hydrolocked. Did you drive through a huge puddle or something and like stop and idle in it?
Old Sep 18, 2007 | 10:41 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
You can take out the trans first then the engine or you can take it out all as one, which is a little harder, but you cant take out just the engine and leave the trans.
Old Sep 19, 2007 | 01:30 AM
MaxBoost925's Avatar
Drug Money
werd.
I suggest taking out tranny first since that's the way we did it.
Old Sep 19, 2007 | 05:57 AM
Abimax95's Avatar
hydrolock
Hi guys well let me put it this way , it almost happen a few times but this time it really did it .. I was driving down a hill not too steap but a hill and it pour like you wouldn't belived it an car drove next to me and hit the the water and it cover my car with water a sec later my car die since I was goin down the hill I pop the clutch and nothing to my amazement I try again BIG mistake I coast down the hill and the engine would not turn so I waited a few hours but to no avial , so the next day I got it to start and to my freaking good luck when it start it it made this clacking noise which it is the piston rod hitting the cylinder wall , plus the front left rear cylinder is not complitly firing the gas (the spark plug is dark).. so know I'm in need to swap the engine ..
Thanks guys for your replies !!
Old Sep 19, 2007 | 06:05 AM
heynow's Avatar
there-there dude, just find another tow mileage VQ, clean it, and be happy!
Old Sep 19, 2007 | 06:33 AM
pmohr's Avatar
No more Maximas...
I was under the impression that although you don't really need to, you could remove the engine with the trans still in the car, supported by the trans mount and a floor jack supporting it from below. Then again he is a 5MT, I can see not being able to get away from the input shaft, the post I had read about was re: 4AT.
...which cylinder?
Old Sep 19, 2007 | 08:48 AM
lexoid's Avatar
That sucks man...
Are you goind to swap the engine by yourself?
Old Sep 19, 2007 | 02:33 PM
Vlasic's Avatar
...which cylinder?
You could do it like that, but why? Taking out the trans is so easy anyways. Plus, when you go to put the engine back in you are going to have less room to maneuver because the transmission will be in there.
Old Sep 19, 2007 | 02:46 PM
pmohr's Avatar
No more Maximas...
Oh I know it's easy, I'm on my 4th
It would really serve no point, but I was just confirming that you could, should you for some random reason have a reason to. I can imagine someone would try it just to avoid removing axles, trans mount, and trans fluid/gear oil.
Old Sep 19, 2007 | 03:50 PM
Vlasic's Avatar
Basically any time you would save not removing the trans would be made up by trying to navigate your way around all the crap you left in, its not worth it.
Old Oct 4, 2007 | 09:02 AM
Abimax95's Avatar
Update on hydrolock engine
Hi guys here is an update , So I decided to swap the engine this last weekend so I didn't want to drive my car for obvious reasons but my stupid *** borther-in-law said is ok to drive since the noise wasn't that loud 2 m inutes from his house I heard the most disturbing noise it was like this CLANCK CLANK and pieces flying out from the bottom of the car but the car ran fine 30 seconds later I hear CLANK CLANK again and all hell broke loose I saw parts flying again and smoke 20 seconds before I get to my brother-in-law's house the car cathes on fire so know I'm waiting how much they give me for my car .. if any in the Mass area is selling a car cheap even if the engine is gone .. let me know ..
Thanks to all ..
Old Oct 4, 2007 | 09:26 AM
BENMAX03's Avatar
wow, gotta love that brotherly advice.
Old Oct 4, 2007 | 10:59 AM
Abimax95's Avatar
yeah , a word of advice Allways trust your instincts !!
Old Oct 4, 2007 | 11:11 AM
jaymemaurice's Avatar
If you're a beginner.. it might be easier to drop the tranny out first, then take the block out... put the new block in and bolt the tranny back up... it will be a pita to leave the tranny in the car and line up the input shaft with the new motor on re-installation... i'd think... the tranny is a lot lighter...
Old Oct 4, 2007 | 11:25 AM
MichMaxFan's Avatar
My question,
How can going DOWN a hill and in heavy rain cause something like this to happen since he did not say he was in a puddle...he was going down a hill. Won't the water just all run off the car?? I don't see how this can happen.
Old Oct 4, 2007 | 12:57 PM
[s3]'s Avatar
Originally Posted by MichMaxFan
My question,
He didn't hydrolock his engine, more than likely he just beat it to death.
The VQ is an amazingly stout motor and would require considerable amounts of torture to kill it. As long as you are not boosting it to death, or running the car with no oil, no coolant, the engine would last quite a long time.
I have seen many high mileage VQ engines torn apart in junkyards with the pistions and cylinders looking in very good shape.
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
