Anyway to "aim" foglights??
Old 10-17-2001 | 07:13 PM
97GreenMax's Avatar
Is there any way to reaim foglights?? My passenger side foglight shines alot lower then my driver side, so I wanted my driver side to shine the same as the otherside. Is there anyway to do this, becuase I did the fogligh rewire, and it ****es me off.
Old 10-17-2001 | 07:24 PM
clee130's Avatar
Yes... search is your friend. Say it with me, "Search is your friend."
http://forums.maxima.org/search.php?...der=descending
Old 10-17-2001 | 07:43 PM
97GreenMax's Avatar
I looked through the search link you put up, and it didn't really help me on my 4th gen foglights.
Old 10-17-2001 | 08:12 PM
WaarrEagle's Avatar
Take the foglight out of the bumper and look on the back. There is a little screw or bolt that you turn to aim the light. I think its sensitive so be careful. Its a pain because you have to reattach the foglight to the bumper before you see what the adjustment did. If you need more instructions I can scan the sheet that came with my OEM foglights that show how to aim them and all if I can find it.
Old 10-17-2001 | 08:27 PM
clee130's Avatar
Sure it does. Third post from the bottom. Named: where I can go to get my headlights reaimed? by Cumalot.
Old 10-18-2001 | 02:23 AM
black019's Avatar
do they beat it in to your head when you become a moderator? say it with me fellas "Use the search function, Use the search function"
Old 10-18-2001 | 06:20 AM
multiplexor's Avatar
hmm i just want to clear something up quickly...
when you say the screw you turn to aim the foglight...
is the screw on the back of the actual foglight piece? or
on the bracket holding it up?
I know theres one screw on the back of the fog light piece itself,
but i was weary of touching it... and there are 3 screws holding up the cage which the fog light is attached to.
hopefully i can get that cleared up
thanks
Old 10-18-2001 | 02:19 PM
WaarrEagle's Avatar
thanks
It in on the back of the housing with the bulb in it. Its probably that one screw you are talking about
Old 10-18-2001 | 03:35 PM
MDr's Avatar
MDr
This is what I follow.
IIRC counter cloc
Q: I have a 4th gen Maxima with the OEM foglights, but they're aimed too low. How do I re-aim them?
A: Next to each of your foglights there's a piece of black plastic held there by a plastic screw. Remove this and
you'll see two 10 mm hex bolts. Remove these and you can pull out the foglight. Don't forget to remove the wiring
harness from the back of the foglight before completely yanking it from the bumper. You will notice an 8 mm hex
bolt on the back of the foglight. Try just a small move at first. The adjustment is pretty sensitive.
Heat0212
10-24-2020 12:36 AM
ricky7780
11-03-2015 03:22 PM
Excalibur23
10-13-2015 04:33 PM
Hdnseek
09-09-2015 05:55 AM
fc95se
11-15-2000 05:14 AM
Quick Reply: Anyway to "aim" foglights??
