BRAKE light on
Old Oct 3, 2007 | 02:26 PM
mendon11's Avatar
BRAKE light on
Hey all,
My BRAKE light turned on a couple days ago and will not shut off. everything looks ok as far as the cables go. i read the sticky and it said the ALT fuse may be blown but this was if both the brake and battery light came on. could this still be the issue? (can't check...at work)
thanks.
Old Oct 3, 2007 | 02:36 PM
99grnmaxgxe's Avatar
Check your brake fluid.
Old Oct 3, 2007 | 02:38 PM
Ruthless's Avatar
the brake and batt light is bad alt or connection to the alt
Old Oct 3, 2007 | 07:43 PM
Nopike's Avatar
If you are low on fluid check for leaks, it does not just evaporate.
Old Oct 3, 2007 | 10:11 PM
maximaserg's Avatar
had that problem
I had that problem.
My back brakes needed to be changed, thats it.
Old Oct 4, 2007 | 06:50 AM
NmexMAX's Avatar
dot dot dot ...
Actually it will get lower as the pads wear down. Check the fluid, and if it's low, odds are you are going to need brakes sometime soon.
This has been indirectly stated in this thread already
Old Oct 4, 2007 | 07:02 AM
Snypa's Avatar
check brakes and fluid.Maybe bad connection hiding somewhere too.
Old Oct 4, 2007 | 07:16 AM
NmexMAX's Avatar
dot dot dot ...
Old Oct 4, 2007 | 11:27 AM
GKourp's Avatar
I just had this problem, put some break fluid in, and started to notice leaks around my rear passenger wheel, figured OK its the break line, well I was wrong, turns out my caliper was cracked, hopefully you don't run into the same trouble I did.
Old Oct 4, 2007 | 12:58 PM
NmexMAX's Avatar
dot dot dot ...
Not good.
Old Oct 4, 2007 | 08:27 PM
67whitegoat's Avatar
I have never come across a cracked caliper....that could have been really bad.
Old Oct 4, 2007 | 08:31 PM
NmexMAX's Avatar
dot dot dot ...
Brake system loses all pressure = to your brakes.
Not good traveling @ 75MPH and you need to slow/stop quick.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
