14MPG WTF?
Old Oct 7, 2007 | 05:31 PM
  #41
67whitegoat's Avatar
^^ Right.....Refer to #39
Old Oct 7, 2007 | 05:59 PM
  #42
dgeesaman's Avatar
Maintenance Monster
That has nothing to do with the purely bad information you put in that post. There is a huge difference between advice and facts.
Dave
Old Oct 7, 2007 | 07:12 PM
  #43
"purely bad information"?... We could go back and forth until the thread is locked. We should agree to disagree.
It's fun though huh?
Old Oct 7, 2007 | 08:06 PM
  #44
KRRZ350's Avatar
Originally Posted by 67whitegoat
Acually, it is. Have you ever had the tank off of a 10 year old car to see the crap that's in the bottom of it?
Wowzers. relax man. dgeesaman is........ well, simply put......... the man! (Even though the bastard never responded to my last pm, but it's cool, I was able to source locally & rebuild a core in time anyways)
The sedimint bs is exaclty that. However there is a benefit to keeping your tank as full as possible,........the more air that is in your tank overnight when the temps drop, the more condensation will build up inside your tank. Water in gas ftl.
Old Oct 8, 2007 | 06:37 PM
  #45
Relax?...Didn't you see the FUN reference.
Even though your both wrong, there's no reason to get mad. We're all good.
Old Oct 8, 2007 | 07:18 PM
  #46
KRRZ350's Avatar
Lol, R u just saying we're both wrong to mess with my head? I swear you are!
But, the laws of physics are pretty simple, on a cool night the warm air in your tank condenses, the more fuel you have in your tank the less water that you will have in your tank, it's as simple as that. And how can you argue with what degeesamna said either? When you think about it, the pick-up IS at the bottom of the tank. I'll give you the mileage thing though, it might be just as accurate as the pump shut-off method, but I usually get within .3mpg when I was doing it a few times in a row.
Old Oct 9, 2007 | 12:24 PM
  #47
I don't dispute the condensation. That part is correct. Your fuel is also a cooling agent for the fuel pump. The more fuel in the tank the better that process works. But every fuel tank has sediment in it ( some more that others ). Yes, the pick-up is on the bottom, but why do you think it has a filter sock on it and an inline filter after the pump.
Your filters keep the "crap" in your tank from getting to the injectors. Other wise, we don't need filters. Now, If with that you can agree that some sediment is in most tanks, you can unerstand parts per thousand. The fuel leaves, the crap in the tank doesn't, resulting in a higher consentration of crap clogging the filters and causing the pump to work harder. End result of running your fuel system to empty all the time is not a catostrophic fuel system failure, just fuel pump failure.
Now, If any of this sounds like "crap", RESEARCH IT.
Find a link to dispute anything I'v stated.
I can find plenty to back it up.
If I'm full of sh*t, I'll step up to the plate and say I'm wrong. Nobody's perfect.
Not even "The Man".
Nothing on this site sould be enough for anyone to get mad about. It's just too much fun.
Old Oct 9, 2007 | 02:06 PM
  #48
Caliplaya023's Avatar
Fresh Outta B-Town, NY
shatty, ive gone 210 miles since filling it and still have a half of a tank left
Old Oct 9, 2007 | 02:07 PM
  #49
NmexMAX's Avatar
dot dot dot ...
I gained 12-15% in MPG w/ LW wheels
Old Oct 9, 2007 | 08:32 PM
  #50
mastere954's Avatar
i started experiencing the same thing after using those octane boost/ injector cleaner products....i stopped using them and now the car is fine...i read that those products make your car run alot richer
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
