Squealing on Start-up
Old Oct 10, 2007 | 06:50 AM
NCSUpilot's Avatar
This just recently began and has not really gotten worse...but on start-up (usually after sitting for a few hours) right when the engine begins running there is a fairly loud squeal. I don't know if this is a belt issue or something more serious. I have not had someone else start the car and me listen to pinpoint exactly where it's coming from, but I will see if I can get someone. Any thoughts?
Thanks!
Old Oct 10, 2007 | 07:25 AM
JwaxMax99's Avatar
Thanks!
Tighten the belt, the noise should go away.
Old Oct 10, 2007 | 07:52 AM
NCSUpilot's Avatar
Would you say tighten at the pulley or tighten via the tensioner from the top?
Old Oct 10, 2007 | 01:52 PM
Ringo1965's Avatar
1997 Nissan Maxima SE
Just had a new serpentine belt put on my car about a month ago. Two weeks no noise then the squealing started. Only on start up, then it would disappear in a few seconds. Just had to adjust the belt tensioner a touch. Check your belt before you adjust!
Old Oct 11, 2007 | 08:11 AM
Divewjason's Avatar
It's probably the belt. I don't know where to tighten it at because I'm not very car savvy myself. But I do know that if you plan on tightening the belt you need to be very careful that you don't tighten it too much.
Here is another topic on it from a seperate forum.
http://www.caraudio.com/forum/showthread.php?t=246415
Old Oct 11, 2007 | 10:03 PM
wiggafly808's Avatar
Loosen the pulley first, or youll bend the tensioner like i did.
I believe the pulley bolt is a 14mm. Loosen that one, but try not to take it all the way off. If everything falls off, it can be a bit tricky to get it back in. Then tighten the tensioner, and make sure to retighten the pulley bolt.
Old Oct 11, 2007 | 10:18 PM
NmexMAX's Avatar
dot dot dot ...
Pinpoint which belt it's coming from, then tighten it. Or, tighten both and eliminate both possible causes.
Old Oct 11, 2007 | 11:12 PM
KRRZ350's Avatar
That's why I recommend, if you haven't done so, download the FSM from phatg20.net or vq35de.com and follow the procedure for measuring the belt deflection, once you do it that way a few times you will be able to get it perfect without having to break out a ruler, but 4-real do it like that the first time, it's THE move!
Old Oct 12, 2007 | 07:21 AM
NCSUpilot's Avatar
Yea, I am afraid to over-tighten. The last belt I had wasn't in that bad of shape, but it would squeak all the time (as the engine is turning). But since I put this new belt on, it has just started squealing on startup. I guess I will take a look at it this weekend and see I can get the deflection correct. I have looked at the procedure, but admittedly just done a guess and check type install. I supposed it pays to do it right.
Old Oct 12, 2007 | 07:34 AM
Punky's Avatar
i had that with my belt too. It's a cheap fix.
belt dressing is a good temporary fix.
Old Oct 12, 2007 | 07:41 AM
Louis's Avatar
:stfu:
Originally Posted by Louis
I have been down that road a few times! I replaced my belts with Nissan factory belts and the idler pulley. If you have changed you belt and it is still squeals you might want to check that out! I haven't had a problem yet and the bearing will go bad in those idler pulley's. And the belts can play a factor also and I only use Nissan or Gates for my belts
Old Oct 12, 2007 | 07:51 AM
maximabebe's Avatar
Just give the tensioner a couple of turns after loosening the pulley to tighten the belt. Symptoms will get progressively worse as the colder weather arrives (depending on where you live). Its not a bad idea to see what kinda condition your belts are in also, as the replacement is quite simple. Good luck.
Old Oct 12, 2007 | 08:03 AM
KRRZ350's Avatar
Lol, I said that in another thread like a week ago, Gate's belts are sick, My buddies mustang would throw every aftermarket belt for his blower after a few k miles, except a gate's. I've been meaning to price one out for the maxi's, I haven't just because the oem belts are so friggin' cheap, but they're not made in Japan anymore, sometimes I get one that says made in USA and then sometimes it's India, wtf lol.
Old Oct 12, 2007 | 12:37 PM
scrubnick's Avatar
If that happens when cranking, it could be the starter. Mine squealed really loud when I started it up and the noise stayed for the first couple seconds the engine was running. Replaced the starter with one from Advance Auto (110 bucks) and it's been fine since.
02PearlSE
Oct 7, 2015 02:12 AM
bill99gxe
20
Aug 1, 2001 08:29 AM
Botnik
Jan 7, 2001 07:32 PM
perlmax90
Dec 6, 2000 03:15 PM
Mike S.
Sep 4, 2000 08:35 PM
