Floor vibration from 1.5k - 2k rpms, after y-pipe install? Leaks maybe??
Old Oct 20, 2001 | 02:46 PM
Synki's Avatar
This didnt start happening till after i installed my y-pipe. The vibration happens right under my foot so this leads me to think that the y-pipe is the cause. If i give it some or little gas between 1.5k - 2k rpms, the vibration begins. Any ideas on how to stop this? This usually happens when the car is warming up all the way to about me driving for 10 mins but then it stops.
Also, when i start the car up in the morning, i see my muffler jerking back & forth a litte but it stops after the car warms up. The noise the muffler makes is kind of a popping sound? Maybe even a gurgle or two. I was told i might have an exhaut leak??
Last, when i give car gas, the y-pipe makes a funny noise. Not so much of bee's in a can but kinda like a nastysounding riced exhaust. I think this can be a bad seal or bad flex section on my y-pipe.
Old Oct 20, 2001 | 04:47 PM
SmoothMax's Avatar
OG
Same thing happened to me when I first installed my y-pipe. You know that big metal thing going down the center of the car on the underside right next to the y-pipe. I think it's part of the engine mount. Well, your y-pipe is vibrating against it. I'm not sure what others did to fix this, but I used a power filer and filed down a small portion of that mount.
Old Oct 20, 2001 | 04:56 PM
Sprint's Avatar
what pipe did you buy?
another issue maybe the cat bracket.. sometimes it causes dash rattles sometimes it causes vibrations..
Old Oct 21, 2001 | 10:01 AM
Synki's Avatar
I got the Stillen 2 piece Y. I will have to stick the car on the lift & see waht the reaosn is. Ill do this after new fuel pump & 3rd suspension swap in 1 shot.
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
