WIRING TO BOOST SENSOR (AKA INTAKE TEMPERATURE SENSOR)
Well, to be completely honest, I've been messing around with putting a high output case fan (Vantec Tornado, for you computer geeks out there) inside the air box. Works fine on the bottom inlet below the filter, but at the top outlet, it put out too much air for the MAF to handle. Like the car would not start.
Now, it might work if the fan came on only at WOT, or if I had a rheostat to control the fan speed...like maybe hooked to the throttle cable.
Anyway, I call it my "stupidcharger."
Got the idea looking at those weird electric "superchargers" some vendors sell on EBay. Those setups use a blower motor, but my little case fan puts out 119CFM, which is way more air than their blower motors.
I figured, for $20, it was worth experimenting with it.
The stock A32 MAF is good for 350 CHP (~297.5 WHP if you have a 5-speed) so it wasn't too much for the MAF to handle. It's because you were cooling the MAF hotwire more due to the increased velocity at idle. The ECU sensed this and added more fuel, but the engine wasn't swallowing as much air as the MAF suggested it was. Therefore the motor ran excessively rich.
No pressurization of air no care. At WOT, the intake manifold is pretty much at atmospheric pressure, so unless you can increase pressure above this point, you won't see any gains.
My fiancee even noticed it without me saying it. She asked me the other day, "What did you do to the car?" I replied, "Why?" She said, "It's running a lot better."
Now, considering that her "butt dyno" is about as saensitive as a concrete block, I'll take that observation as a positive.
There's nothing wrong with getting more cooler air to the throttle, and that is basically what the fan is doing. It's like why people install less restrictive air filters. If nissan had it right, they would have made K&N OEM equipment.
Thanks for the Info! I assume when you say big scoop thing, its that black tube, thats in the vincinty of the absolute pressure sensor from your original pic?
Directly below the red box, the scoop with the weatherstripping.
Wow, can't believe how old this pic is...before I painted my UIM and front VC black (out of boredom), pre intake, still original battery, and looks like pre-tint, too.
Found an old pic I must've used for another intake thread:
Thanks for the pic, pmohr. I went ahead and pokeD around looking for the IAT tonight, took a pic, I assume this is the IAT here. Thanks for all your help.
Then again, it could be that in 1998 they left it off both A32's, but, in my stock snorkle, there is not even an opening, whereas in the extra 4th Gen stock box I bought (for my experiments), the snorkle had a hole in the side...which, of course, was empty. Never knew what was supposed to go there, until tonight.
Mistery solved...except I still cannot find an IAT anywhere under my hood.
I may be wrong, I know that that thing in the red box is only on the 95. well atleast from every max ive ever seen. I was pretty sure at the time that that was the 95's absolute pressure sensor. all it has is one pipe going into it and nothing out so. mostly an assumption
One more question regarding the IAT sensor. When I replaced my starter I must have not inserted the connection for the sensor correctly, thus I was getting the a check engine light for the IAT. Now that I reconnected last night do I need to reset my ECU?
The Frye
Sep 2, 2021 11:03 AM
lux97Max
Sep 4, 2015 05:42 PM
