E-brake
Old Oct 20, 2007 | 08:04 AM
huggs97max's Avatar
E-brake
My E-brake doesn't work how do I find out which cable is broken?
Old Oct 20, 2007 | 09:02 AM
nitromax's Avatar
look at the position of both cable ends at the calipers ( note length of flexible rubber cover on cable helps here ) with the ebrake off. pull the ebrake handle up as far as it will go, recheck the cable ends to see if both pulled in the same distance, now release the ebrake & recheck that they both returned to original position. the one that didn't pull in is the bad one. be sure calipers function properly. OR you could just jack the car up with wheels hanging free, put the ebrake on and try to spin/turn the wheels by hand. the one that spins/turns has the bad cable or caliper.
Old Oct 20, 2007 | 09:50 AM
BiZzL3's Avatar
what do i do if only one of my tires stop and the other doesent??? same?
Old Oct 20, 2007 | 05:49 PM
nitromax's Avatar
yeah, if you're checking the ebrake function.
Lowered_a33
Aug 24, 2015 04:35 AM
Adambrown_2001
Feb 27, 2002 01:41 PM
buckwilly4
Sep 20, 2001 02:37 PM
Max2000
Nov 24, 2000 05:56 AM
PiotrC70
Nov 17, 2000 08:06 PM
