car is stallin at startup...WTF!!!
Old Oct 21, 2001 | 09:43 AM
NyC97Max's Avatar
hey i kinda got a problem...i just changed my spark plugs for my 60K tuneup...i did it about a 1000 miles late cuz ive been busy..and i used NGK plat...and i also changed the air filter to a K&N drop-in..changed the fuel filter, PCV valve, started using mobil 1 synthetic motor oil...but i put in the plugs a few weeks after the rest of the stuff...and when i started the car with the new plugs in...it started for a second and then just died..then i tried it again...same thing...and then finally i had to give sum gas upto about 3000 RPM for two secs to keep the car on...this scared me and i wanna kno wasssup?? also another thing....my K&N doesnt fit EXACTLY perfect into the housing...its about a 1/2" small, but i checked with like 5 auto parts stores and its the right filter number and everything...but my idle is at about 500, sumtimes maybe 600...can the lil space in the air filter be the prob?? is this just how the K&N fits...or should i just go with a stock OEM filter for like $10?? help me here...dont want my car to screw up
Old Oct 21, 2001 | 09:44 AM
Sonic's Avatar
Check that you didn't pull a vacuum hose off, and check to make sure that all the ignition coil plugs are connected.
Old Oct 21, 2001 | 09:52 AM
njmaxseltd's Avatar
The K&N filter should fit perfectly the correct P/N is 33-2031-2. There should be no gaps at all around the filter. If the P/N on the box is correct, perhaps the wrong element was in the box you got.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
