missfire at WOT
Old Oct 29, 2007 | 08:23 PM
WielkiWaac's Avatar
MaximaDriver
missfire at WOT
Ok so I was going back home from work and I wanted to push my baby stronger than usually. At 4th gear doing around 110 mph my SES started blinking and I felt loose of power. I know that was misfire. After i slowed down it stopped blinking. When I got home i pulled code and it showed me p0302 which is cyl# 2. Is it possible it was misfiring because i had almost empty fuel tank? If not, what is the reason that it misfires at WOT not other other load? my ***** is 99 and has almost 100k miles.
thanks for any info
Old Oct 30, 2007 | 07:15 AM
JtzMax's Avatar
Whatchyou say?
change your plugs recently? if not ... i'd try that and see if it helps.
Old Oct 30, 2007 | 07:35 AM
Mctwist77's Avatar
Check your fuel injectors.
Old Oct 30, 2007 | 07:42 AM
Snypa's Avatar
check sparks....btw, what is WOT.?
Old Oct 30, 2007 | 07:43 AM
hot_wax_tree's Avatar
Well first off you were putting your car under a lot of pressure so you are creating problems by driving like that. But your problem is probubly just a spark plug if shes not that old and only 100k and you driving like that I would venture a guess of a bad spark plug.
Old Oct 30, 2007 | 08:43 AM
pmohr's Avatar
No more Maximas...
Wide Open Throttle.
thanks for any info
Are you on the original coils? 99's are well known for faulty coil packs.
Old Oct 30, 2007 | 08:50 AM
Coilpacks.............................
Old Oct 30, 2007 | 08:37 PM
WielkiWaac's Avatar
MaximaDriver
Originally Posted by pmohr
Wide Open Throttle.
yea. cyl 2,4 and 6 have old coil packs (100k miles). I didnt have a chance to switch them around and see what happen. Maybe Thursday
Old Oct 30, 2007 | 08:57 PM
nafddur's Avatar
I had a similar experience about 1 1/2 years ago with my 95 SE, then with just over 170K miles. It had been years since I had opened it up, so late one night just for fun I cranked it up to a little over 100 on an empty highway, and shortly after noticed a severe miss (don't remember if the SES light came on).
Turned out, the electrode had burned off one plug, and I was running on 5 cylinders. Changing the plugs - which hadn't been done since 100K anyways - solved the problem. But I do suspect that use of the original coils (still in the car, by the way) might have exacerbated the melted plug problem.
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
ballerchris510
Sep 10, 2015 09:35 PM
t6378tp
Aug 24, 2015 07:03 AM
N2deep
Aug 16, 2015 08:30 PM
