Difference in drivers axle? Auto vs manual
Old Nov 2, 2007 | 01:04 AM
Maxima_Joe's Avatar
4th Gen Parts King
What is the difference on the drivers axle from autos to manuals?
This would be for non-lsd.
I have alot of axles laying around. Some are autos and some are manuals but i can't tell the difference.
Just for curiosity.
Is the lsd passenger axle the same for auto and manual?If not what is the difference? How is it different from non-lsd?
What about the lsd drivers? How is the auto and manual different?What is the difference between them and non-lsd.
Old Nov 2, 2007 | 05:33 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Not sure about the difference between the drivers side, maybe length.
As for passenger side, I think they are all the same, manual, auto, LSD, what ever.
Old Nov 2, 2007 | 06:18 AM
pmohr's Avatar
No more Maximas...
I thought someone here found a difference between the support brackets in 4AT and 5MT passenger axles?
Old Nov 2, 2007 | 08:13 AM
ShiftVQ35
the manual drivers axle is shorter then the drivers auto axle.
Old Nov 2, 2007 | 06:45 PM
Maxima_Joe's Avatar
4th Gen Parts King
Yes they are different. It's the angle thats different though. Nothing to do with the axle.
What part is shorter?
Old Nov 5, 2007 | 01:15 AM
Maxima_Joe's Avatar
4th Gen Parts King
Anybody else know?
Old Jul 5, 2009 | 11:44 AM
Maxima_Joe's Avatar
4th Gen Parts King
Anybody know how to tell them apart? I was told the lines at the end entering the trans depending on if they were horizontal or vertical determined if they were auto or manual. I have used both vertical and horizontal on both manual and auto cars.
Old Jul 5, 2009 | 11:58 AM
pmohr's Avatar
No more Maximas...
Indeed, the only thing I see different is the oil channels on the end.
Hmm...funny thing is, FAST shows that both autos and manuals can both use the same part number inner joint/stub shaft. The center shaft appears to be the same as well.
Surely it's not possible that they're just interchangeable.
Do you happen to have both an auto and a 5 speed laying around up there? I would just start trying them out.
Old Jul 5, 2009 | 05:38 PM
brucerap's Avatar
Rock Auto shows a bunch of different variations (1996). Same part # for mt and at if w/o abs and ld. Different numbers for other variations.
Old Jul 8, 2009 | 01:10 AM
Maxima_Joe's Avatar
4th Gen Parts King
All 4th gens use the same passenger side axle - LSD, open, auto, manual, they're all the same.
The driver's side axle is different between auto and manual, and different between LSD and open diff, so there are 4 different axle shapes for the driver's side.
Some info previously posted by Nealoc187
I have also sent an email to Marty at raxles to see if he can shed some light on the matter.
Old Jul 22, 2009 | 08:31 PM
Maxima_Joe's Avatar
4th Gen Parts King
OK never heard back from Marty.
On the 5 axles I have with vertical oil channels. The inner joint is 1/8 inch
longer on 3 of them compared to the other 2. The other 2 are identical to the 6 axles I have with horizontal oil channels.
So the longer ones must be the manual ones.
boomerbrian
Nov 8, 2015 05:10 PM
kingw323
20
Oct 21, 2015 08:36 AM
PH98I30
Aug 20, 2015 04:25 PM
ef9
Aug 13, 2015 01:19 AM
