Giw to install my HID conversion kit on my 4t gen.
Old Nov 17, 2007 | 12:23 PM
maximaserg's Avatar
how to install my HID conversion kit on my 4t gen.
Can anyone show me how this is done?
Old Nov 17, 2007 | 12:53 PM
Nightkid08's Avatar
where are you located?
Old Nov 17, 2007 | 12:54 PM
maximaserg's Avatar
i meant through diagrams online.
Old Nov 17, 2007 | 01:02 PM
J-hop's Avatar
quite a bit of stuff on google, some you might wanna check out:
http://www.xenonsgroup.co.uk/installationguide.pdf
and a vid
http://www.youtube.com/watch?v=dvhDGMUV4pg
Old Nov 17, 2007 | 04:57 PM
Aramel's Avatar
Is there anything specific to a 4th Gen Maxima that I should be aware of before installing an HID kit? I'm putting an H4 replacement kit in because I've converted my headlights to Cefiros. Anything regarding fuses that I may not be aware of? Would you recommend a relay cable or is it okay to go ahead without one?
Old Nov 17, 2007 | 05:31 PM
96blkonblkse's Avatar
^^You should be okay without a relay kit. Although some will recommend it due to the initial power consumption of the hid ballasts, but most do fine with out them.
to the OP. Honestly im not trying to be a **** or anything, but have you looked at the kit, seriously if you can tie your shoes you can install the kit, theres 4 things you have to plug in, and they only fit on the right one.
Its best off if you look at it first then try figure out before you ask questions, with something like this it is very simple so i suggest you look at them, install them and if you have any questions then post and ask!
Again im not trying to be a **** or anything, but seriously first you post asking if a +45 wheel will fit, without giving us the rim width or diameter for that, then you post this.
Old Nov 17, 2007 | 07:13 PM
bigpulve+'s Avatar
He likes to be thorough?
Old Nov 17, 2007 | 10:30 PM
Who knows. But if i was in his case id look at the instruction manual that came with them. Serioulsy its not hard to install, i didnt even have an instruction manual and i still got it right.
I will give you this information although i dont think it will help much as you have to be aware of what your doing or it wont work.
Before you plug the main connector that plugs into your original harness, make sure the pins are in the correct location. I find sometimes they are mixed up, like instead of the positive being where it should its on the opposite side. Other then that you should have any issues.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
