leaking engine coolant
leaking engine coolant from the passenger side . i noticed it leaks when i park my car and it stand there over night or for longer time . the leak seems to be some where by the tire anyone knows what can it be ?
it usual the seals that go wrong on them but i would always replace it if your going to do the seals. i just got mine replaced last month, i was too busy to do it myself so i had to put some green down
First timer, I'd say a few hours, most of which is time spent finding all the hiding 10mm (head) bolts, forgetting about the two long 12mm (head) bolts hiding behind the lower oil pan, and getting that damned PS pump out of the way.
Getting it back on...is a different story. Have fun with the RTV, is all I can really say.
Doesn't really make sense to remove the timing cover for a water pump job. Without removing the entire cover me and a bud took about an 1 1/2 hours to replace the water pump from jacking the car up to starting it. That includes some wasted time as well.
to replace them i wouldnt take off the timing chain cover, i didnt when i had to do mine. but ya it will take a good afternoon to do.
Mar 12, 2020 12:06 AM
ag90fox
Sep 9, 2015 12:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
