Air intake recommandation.
Old Nov 18, 2007 | 06:33 PM
hermtm2's Avatar
Hi.
I'm looking for an air intake. My car has a starting problem. I will try to replace the air intake to fix the problem. Which brands are good for 96 I30?
Thanks.
Old Nov 18, 2007 | 06:40 PM
Fr33way™'s Avatar
Wild for Width
OEM Nissan.
Old Nov 18, 2007 | 06:42 PM
EnervinE's Avatar
i has college
Originally Posted by Fr33way™
OEM Nissan.
Maintenance before mods. And an air intake will not fix your problem, describe the problem further.
Old Nov 18, 2007 | 06:49 PM
Snypa's Avatar
why r u looking an air intake if your cr wont even start.?get that fixed first buddy.
Old Nov 18, 2007 | 07:12 PM
crazy97's Avatar
Originally Posted by hermtm2
Hi.
Thanks.
You stated once before that your car was hard to start only when hot. Is that correct?
Old Nov 18, 2007 | 07:21 PM
hermtm2's Avatar
When the engine is normal temperature, the hard staring problem came up mostly.
In the mornig when the engine is cold, the start is just normal. But after sitting 5~10min., it need a long crank time. When I tested to start without air intake, it was good to start. So I was thinking the air intake has a problem.
Nobody has the solution for the hard starting problem. I wouldl like to tell about the history of repair.
My I30 has the starting problem before I bought.
Only what I knew about the problem, the problem was started after the transmission was rebuilt. Right after the A/T was rebuilt, the car wasn't started at all. So it was repaired to the problem on the another shop.
It was the labor description.
CRANKS BUT WILL NOT START ------------ $192
HAS SPARK AND INJECTOR PULSE. HAS GOOD FUEL PRESSURE.
INSPECTED SPARK PLUGS AND FOUND PLUGS GAS FOULED.
REPLACED SPARK PLUGS WIHT O/E STYLE.
CARBON BUILD UP CAUSING HARD START WHEN COLD.
NEEDS TO CLEAN MOUNTING SURFACE BETWEEN ENGINE AND
TRANSMISSION. REROUTE GROUND CABLE TO THE STATER BOLT.
CLEAN MATING SURFACE BETWEEN TRANSMISSION AND ENGINE.
INSTALLED GROUND CABLE TO THE STARTER BOLT. AFTER CLEANING
VEHICLE NOW STARTS AND RUNS. -------------- $352
When the repair was done, the start was good like normal. However after one month, it was getting worse. Like three times every 10 times was hard to start.
On two months later I've infiniti dealership and import car specialist but they just told me that
1.the error code P1320 even though the car haven't show up the CEL. (I don't know how did they get the code.) So it might be needed to replace all of the ignition coils -$950.
2. Also the ECU could be malfunctioned. It should go to dealership.
3. The carbon could be accumulated inside the engine.
After that, I replaced the ignition coils and crankshaft sensor but nothing. I spent about $1000 to try to fix the problem. But I'm missing now.
What can I do for my car? I love my car. It is nice without the problem.
Old Nov 18, 2007 | 07:30 PM
MorpheusZero's Avatar
Do NOT replace the coils to the tune of a grand. These can be had for far less and you can do this yourself.
I take it the car is cranking but not firing up?
Old Nov 18, 2007 | 07:41 PM
hermtm2's Avatar
I replaced the coils by myself. And the car is started after 3~5 times to turn, when the engine is hot.
Old Nov 18, 2007 | 07:55 PM
crazy97's Avatar
How does the air filter look?
Old Nov 18, 2007 | 08:15 PM
hermtm2's Avatar
The filter was replace 2 weeks ago. It just looks fine.
Old Nov 18, 2007 | 08:33 PM
crazy97's Avatar
I knew someone with another car that had this sort of thing happen when hot, but it also would sometimes cause it to lose power/cut out while driving..ended up being the CPS camshaft position sensor.
Old Nov 18, 2007 | 09:14 PM
hermtm2's Avatar
I replaced the sensor at the last weekend but it was nothing to me.
Also I tried to start with disconnecting the sensor but the car wasn't started at all.
It just cranked. So I think that the sensor and wire are ok.
Old Nov 19, 2007 | 10:12 AM
oVeRdOsE's Avatar
Does your idle is good? If yes, you don't have an intake problem.
I maybe know whats wrong : you said after the cleaning everything was good. So my guess : rust and oxydation. If you clean the housebell and the engine block badly, the problem is fix for a while, until the oxidation come back.
It was my situation, use dielectric grease on the main screws (tranny to the engine block). Make sure that you remove all the antitrust with a sand paper.
Do specially the screws located under the car. In that way you sure that the oxidation wont come back.
Takes 20 minutes...
Does you problem look like this?:
http://videos.streetfire.net/video/8...8f0096156c.htm
Old Nov 19, 2007 | 03:01 PM
TunerMaxima3000's Avatar
I still say its a poor ground but whatever.
A lot of people don't know how to properly clean and ground connections, and how important it is to do so, and that likely includes most of the mechanics as well.
Old Nov 19, 2007 | 03:29 PM
hot_wax_tree's Avatar
Well just think you need 3 things to run an engine.
1.fuel
2.spark
3.air
if your missing one you will not work, you know for sure your getting spark the shop told you
you are sure that your getting air? or fuel. maybe try running some key cycles befor you just get in a nturn it on. this will give the fuel pump and other components a chance to turn on and get ready. if you want me to tell you about key cycles you can PM me
Old Nov 20, 2007 | 07:18 AM
hermtm2's Avatar
The car has perfectly the same situation when the engine is hot especially.
I have to turn my key at leat 3 times. After started to the engine, everything is fine like good idle, accelaration and etc... I say that just normal.
Would let me know the way to clean tranny to the engine block more specifically? I knew what the dielectric grease and sand paper are. But what is the "antitrust"? I would like to know the whole process. Could you give an e-mail if you have picturs of the job? I will try your way as soon as you let me know.
Takes 20 minutes...
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
