Anyone else notice excess heat from inside cabin when accelerating?
Old Nov 19, 2007 | 05:32 PM
shadyonedeath's Avatar
Its usually when im on the freeway, but my leg area heats up when im speeding up.
I just replaced my Waterpump so i know there coolant circulating..
Old Nov 19, 2007 | 05:34 PM
DSM Storm's Avatar
I cant say that ive had this problem. Is it comming from the vents? or do you notice the carpet getting warm?
Old Nov 19, 2007 | 05:36 PM
DJMaxGLE's Avatar
I assume this happens when your heater is turned off? For some strange reason, Nissan made the Maxima so that it continues to blow air through the floor vents even when your system is turned off. Push the circular button and it should stop.
Old Nov 19, 2007 | 05:44 PM
Yea this. It comes from the vents.
Old Nov 19, 2007 | 06:16 PM
maxx0831's Avatar
Yeah I have the same problem. Its gets hot.
Old Nov 19, 2007 | 06:20 PM
NmexMAX's Avatar
dot dot dot ...
You see what was done there?
This is the problem/solution/explanation.
Old Nov 19, 2007 | 06:48 PM
andrei3333's Avatar
This is a good thing. Especially noticeable when you flush the whole coolant system and use new and proper non-silicated nissan long life coolant.
Set the recirculation button to not allow outside air to come into the cabin as mentioned above, also set the temperature in the middle between the hot and cold and you will not feel a thing as this closes the heater core.
I like to use this hot air on the hwy without turning my heater on, saving fan life maybe I duno why, but i like it...
Old Nov 19, 2007 | 06:59 PM
MaximaPimpin's Avatar
Heh thats exactly what I do. If im cold i just put it on warm and never actually turn on my heater and it does the job. Helps save gas.
Old Nov 19, 2007 | 07:47 PM
Innovative...
Old Nov 20, 2007 | 08:42 AM
ThurzNite's Avatar
So this has nothing to do with rpm and operating temp of the engine?
Jae
Old Nov 20, 2007 | 10:12 AM
DomoMaxima98's Avatar
Yeah its getting cold.. appreciate the heat and dont worry about having to turn it on... i do it all the time..
Old Nov 24, 2007 | 12:50 AM
clint240sx's Avatar
^^^as do I, it will also blow cool air if you have had the a/c set cold.
thenewguyy
Sep 12, 2015 11:12 AM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
